Integrating Higher Powers of Tangent: A Shortcut Using Trigonometric Identities
  • MHB
  • Thread starter karush
  • Tags
    Dx
In summary, the integral I_{6a} can be evaluated using the identity $\tan^2 x= \sec^2 x-1$ by first expanding the integrand and then applying the identity multiple times. The final result is given by I=\frac{1}{3}\tan(x)\left(\sec^2(x)-4\right)+x+C.
karush
MHB
3,269
7.2.6a use $\tan^2 x= \sec^2 x-1$ to evaluate
$$\displaystyle I_{6a}=\int\tan^4 x \, dx$$
well my first inclinations is to.
$$\int(\sec^2 x-1)^2\, dx$$
then expand
$$\int (\sec^4 x - 2 \sec^2 x +1)$$
ok not sure if this is the right direction
W|A returned this:
I would write:
\(\displaystyle I=\int \tan^2(x)(\sec^2(x)-1)\,dx=\int \tan^2(x)\sec^2(x)\,dx-\int \tan^2(x)\,dx\)
The first integral is straightforward ad for the second, apply the identity again:
\(\displaystyle I=\frac{1}{3}\tan^3(x)-\int \sec^2(x)-1\,dx\)
\(\displaystyle I=\frac{1}{3}\tan^3(x)-\tan(x)+x+C\)
Now, let's factor:
\(\displaystyle I=\frac{1}{3}\tan(x)\left(\tan^2(x)-3\right)+x+C\)
Apply the identity again:
\(\displaystyle I=\frac{1}{3}\tan(x)\left(\sec^2(x)-4\right)+x+C\)
that is cool..
so many examples went for the U substitution optionalways seem to get the best help here
Mahalo
MarkFL said:
I would write:
Now, let's factor:
Nicely done! (Bow)
-Dan
1. What does "274 7.2.6a int tan^4 x dx =" mean?
This notation represents the integral of tan^4 x with respect to x, evaluated at 7.2.6a and multiplied by 274.
2. How do you solve "274 7.2.6a int tan^4 x dx ="?
To solve this integral, you can use the power rule for integration and then evaluate the integral at 7.2.6a. The final answer will be multiplied by 274.
3. What is the purpose of using "274 7.2.6a" in "274 7.2.6a int tan^4 x dx ="?
This notation indicates that the integral is being evaluated at a specific value of x, in this case 7.2.6a. This allows for a more precise calculation of the integral.
4. Can you provide an example of solving "274 7.2.6a int tan^4 x dx ="?
Sure, for example, if the original integral was "int tan^4 x dx", you would use the power rule to get 1/3 tan^3 x + C. Then, when evaluating at 7.2.6a, the final answer would be (1/3 tan^3 7.2.6a) * 274 = 274/3 tan^3 7.2.6a.
5. Are there any special considerations when solving "274 7.2.6a int tan^4 x dx ="?
One special consideration is that the integral of tan^4 x can also be expressed as (sec^2 x - 1)^2. So, when solving this integral, you may need to use trigonometric identities to simplify the expression before using the power rule.
  • Calculus
  • Calculus
  • Calculus
