Predicting Outcome of 2D Collision w/ Initial Quantities
In summary: Originally posted by mathman The Newtonian 3-body problem has a unique solution -- it just doesn't have a closed-form solution (i.e., a simple formula in terms of algebraic functions). That means in practice you have to resort to numerical approximation, although you can make the approximation as good as you like.
StephenPrivitera
363
In my text, it says that the conservation laws alone do not suffice to predict the motions of two particles if the collision occurs in two dimensions. It is generally required that we know one of the final quantities in order to predict the rest. Does this mean that it is impossible to predict the outcome of a two dimensional collision using only the initial quantities? That is, is there some other unknown quantity (ie, other than velocity and mass) that would allow one to predict the outcome?
There is one degree of freedom. Imagine a collision between two billiard balls on a pool table. The direction after collision is determined by the exact point of impact. On a microscopic scale, there cannot be an exact point of impact, so the direction after collision is based on a probability distribution.
The initial conditions determine the final state, it's just that to figure out what that final state is, you have to look at the shapes of the objects, the details of the contact forces between them, etc.
Excellent! That's exactly what I suspected. I tried to solve the problem under the assumption that I knew the exact point of impact and I got a very complicated result (it was very tedious and I gave up after finding one of the final components of one of the masses). But I suspected that the unknown quantity was the direction of the impulse during the collision.
By the way, what exactly is a degree of freedom?
My astronomy professor said once, "The three-body problem is unsolvable because there are too many degrees of freedom" (or hopefully something close to that). This "unsolvable" problem also bothers me, because nature ought to be predictable. What makes the three body problem so difficult? Is it similar to the 2D collision problem in that some unknown cannot be known precisely?
Would you say that this is due to a weakness of some sort in the manner of our mathematics? That is, is this problem difficult more due to the mathematics involved or more due to the physics? I have no idea what the solution looks like. It's just that I believe strongly in the power of math and it disappoints me when "numerical methods" have to be used.
Neither. It's just that many -- in fact, most -- functions do not have closed-form formulas. For instance, many functions can only be expressed algebraically as infinite series. The 3-body problem happens to be an example of an equation whose general solution is not closed-form. There are infinitely many such equations; this one is just famous because a lot of people were interested in it. It's not a limitation of mathematics or anything; if anything, it's a limitation in what functions we consider to be "nice" (i.e., ones that we can write down simple formulas for).
1. How do you predict the outcome of a 2D collision?
The outcome of a 2D collision can be predicted by using the laws of conservation of momentum and conservation of energy. This involves analyzing the initial quantities of the objects involved in the collision, such as their mass, velocity, and direction.
2. What are the initial quantities needed to predict the outcome of a 2D collision?
The initial quantities needed to predict the outcome of a 2D collision include the mass, velocity, and direction of the objects involved in the collision. These can be measured or calculated using known values.
3. How do you account for external forces in predicting the outcome of a 2D collision?
In most cases, external forces are negligible in a 2D collision and can be ignored. However, if there are significant external forces present, they can be accounted for by including them in the calculations for conservation of momentum and energy.
4. Can the outcome of a 2D collision be accurately predicted?
Yes, the outcome of a 2D collision can be accurately predicted using the laws of conservation of momentum and energy. However, there may be some discrepancies due to external forces or other factors that may not have been accounted for.
5. How can the predicted outcome of a 2D collision be tested?
The predicted outcome of a 2D collision can be tested by conducting an actual collision and comparing the results to the predicted outcome. This can help to validate the accuracy of the predictions and identify any discrepancies that may need to be accounted for in future calculations.
  • Mechanics
  • Mechanics
