2d elastic collision of two round objects
  1. Sep 5, 2008 #1
    Hi.
    I'm new to vector physics, and I'm trying to write a function to predict the rebound vectors of two circles impacting. To this end, I wrote the following function in Flex. My problem is that the y components that get calcuated ( v1_final_y and v2_final_y ) are always equal to the original y components. I'm doing something wrong, and I thought I understood what I was doing, but I must be miscalculating something. Can anyone point me in the right direction?
    Thanks in advance!
    public static function ReboundCircleToCircle( aVector:CCommonVector,
    bVector:CCommonVector ) :void
    /* CALCULATE THE NORMAL VECTOR */
    var n_x:Number = bVector.x - aVector.x;
    var n_y:Number = bVector.y - aVector.y;
    /* CALCULATE THE LENGTH OF THE VECTOR */
    var vx_len:Number = Math.sqrt( Math.abs( ( n_x * n_x ) + ( n_y * n_y ) ) );
    /* CALCULATE THE UNIT NORMAL VECTOR */
    var un_x:Number = n_x / vx_len;
    var un_y:Number = n_y / vx_len;
    * THE UNIT TANGENT VECTOR IS A PERPENDICULAR LINE TO THE
    * UNIT NORMAL. SO X = -Y AND Y = X
    var ut_x:Number = -un_y;
    var ut_y:Number = un_x;
    * PRE-COLLISION VELOCITY VECTORS, IF NOT
    * ALREADY VECTORS, ARE JUST THE X & Y COORDS
    * OF THE INITIAL VELOCITIES
    var v1_x:Number = aVector.x;
    var v1_y:Number = aVector.y;
    var v2_x:Number = bVector.x;
    var v2_y:Number = bVector.y;
    * NOW WE FIND THE PRE-COLLISION SCALAR, OR DOT-PRODUCT
    * OF EACH OBJECT ALONG THE UNIT NORMAL AND UNIT TANGENT
    * VECTORS.
    var v1n:Number = ( un_x * v1_x ) + ( un_y * v1_y );
    var v1t:Number = ( ut_x * v1_x ) + ( ut_y * v1_y );
    var v2n:Number = ( un_x * v2_x ) + ( un_y * v2_y );
    var v2t:Number = ( ut_x * v2_x ) + ( ut_y * v2_y );
    * THE VELOCITY SCALAR ON THE TANGENT VECTOR BEFORE AND AFTER
    * COLLISION IS THE SAME....
    * I'M REFERRING TO POST-COLLISION CALCULATIONS
    * AS PRIME...
    var v1t_prime:Number = v1t;
    var v2t_prime:Number = v2t;
    * FIND THE NEW "NORMAL" VELOCITIES, OR THE VELOCITIES
    * ON THE NORMAL VECTOR. USE 1D COLLISION FORMULAS.
    var v1n_prime:Number = ( ( v1n * ( aVector.Mass - bVector.Mass ) )
    + ( ( 2 * bVector.Mass ) * v2n ) ) / ( aVector.Mass + bVector.Mass );
    var v2n_prime:Number = ( ( v2n * ( bVector.Mass - aVector.Mass ) )
    + ( ( 2 * aVector.Mass ) * v1n ) ) / ( aVector.Mass + bVector.Mass );
    * CONVERT THE SCALAR NORMAL AND TANGENTIAL VELOCITIES INTO VECTORS
    * TO DO THIS,
    * WE MULTIPLY THE UNIT NORMAL VECTOR BY THE SCALAR NORMAL VELOCITY.
    * THE PRODUCT OF A VECTOR TIMES A SCALAR IS A VECTOR
    * WHOSE COMPONENTS
    * ARE BOTH THE ORIGINAL VECTOR COMPONENTS MULTIPLIED BY THE SCALAR.
    var v1n_prime_vector_x:Number = un_x * v1n_prime;
    var v1n_prime_vector_y:Number = un_y * v1n_prime;
    var v2n_prime_vector_x:Number = un_x * v2n_prime;
    var v2n_prime_vector_y:Number = un_y * v2n_prime;
    var v1t_prime_vector_x:Number = ut_x * v1t_prime;
    var v1t_prime_vector_y:Number = ut_y * v1t_prime;
    var v2t_prime_vector_x:Number = ut_x * v2t_prime;
    var v2t_prime_vector_y:Number = ut_y * v2t_prime;
    * FIND THE FINAL VELOCITY VECTORS BY ADDING THE NORMAL AND
    * TANGENTIAL COMPONENTS
    * FOR EACH OBJECT.
    * TO ADD TWO VECTORS, JUST ADD THEIR COMPONENTS.
    var v1_final_x:Number = v1n_prime_vector_x + v1t_prime_vector_x;
    var v1_final_y:Number = v1n_prime_vector_y + v1t_prime_vector_y;
    var v2_final_x:Number = v2n_prime_vector_x + v2t_prime_vector_x;
    var v2_final_y:Number = v2n_prime_vector_y + v2t_prime_vector_y;
    * UPDATE THE VELOCITIES OF THE TWO OBJECTS
    aVector.VelocityX = v1_final_x - aVector.x;
    aVector.VelocityY = v1_final_y - aVector.y;
    bVector.VelocityX = v2_final_x - bVector.x;
    bVector.VelocityY = v2_final_y - bVector.y;
    * UPDATE THE X AND Y COORDINATES OF THE TWO OBJECTS
    aVector.x += aVector.VelocityX;
    aVector.y += aVector.VelocityY;
    bVector.x += bVector.VelocityX;
    bVector.y += bVector.VelocityY;
Draft saved Draft deleted
