Solving 2D Elastic Collision Problem in Physics
In summary, the conversation discusses a physics problem involving two particles of different masses colliding elastically and finding the possible initial velocities and direction of one of the particles. Different approaches have been attempted, including using trigonometry and conservation of energy, but the exact solution has not been found yet. The use of vector-based analysis has not been explored due to the level of the textbook. However, it is suggested that conservation of kinetic energy and momentum can be used to solve the problem.
mgrantbaker
Came across this one in my freshman physics book:
A particle of mass 1m is traveling along the x-axis at velocity V1. It collides elastically with a second particle of mass 3m traveling at velocity V2. The first particle (1m) moves off at 0.92m/s at 48º to the x-axic. The second particle (3m) moves off at 1.2m/s at 17º to the x-axis. Find two sets of possible values for the initial velocities for both particles and the direction of the second particle (3m).
I've tried brute forcing it with trigonometry/dot-producting the momentum equation and using that with conservation of energy, but I ended up with an equation for the initial direction that was way too complex to solve. Also tried reversing the collision, shifting the angles, and then translating into a rest frame for one of the particles. That approach yielded a direction for the 3m particle that was close to one of the two possible answers, but still not right. Plus, my math (which probably has some mistakes) didn't leave the potential for two results.
I haven't attempted a full vector-based analysis (breaking the collision into normal and trangent vectors) since this is from a freshman level book, and that method is beyond the scope of the chapter. So what am I missing here?
If the collision is elastic, then you can use conservation of kinetic energy. Also, since velocities are constant before and after the collision no external forces are acting on the projectiles and momentum is conserved, so you can separate the momentums into equal x and y components.
I would suggest approaching this problem using the principles of conservation of momentum and conservation of energy. These principles state that the total momentum and energy of a system before and after a collision remains the same.
To solve this problem, we can first write the equations for conservation of momentum and energy:
Conservation of momentum:
m1V1 + m2V2 = m1V1' + m2V2'
Conservation of energy:
1/2m1V1^2 + 1/2m2V2^2 = 1/2m1V1'^2 + 1/2m2V2'^2
Where m1 and m2 are the masses of the two particles, V1 and V2 are the initial velocities, and V1' and V2' are the final velocities.
We can then use the given information to solve for the final velocities of the particles. From the given data, we can write the following equations:
V1' = V1cos48º + V2cos17º
V2' = V1sin48º + V2sin17º
Substituting these equations into the conservation of momentum and energy equations, we can solve for V1 and V2. This will give us two sets of possible initial velocities for the two particles.
To find the direction of the second particle (3m), we can use the equation for conservation of momentum and solve for the angle between the initial and final velocities. This will give us two possible angles, one for each set of initial velocities.
If your calculations have resulted in a complex equation for the initial direction, it is possible that there is a mistake in your calculations. I would suggest double checking your work to ensure accuracy.
Additionally, while a vector-based analysis may be beyond the scope of the chapter, it can still be a useful approach to solving this problem. It may be worth exploring this method further to see if it yields the correct results.
1. What is a 2D Elastic Collision in Physics?
A 2D elastic collision in physics is a type of collision between two objects in which both kinetic energy and momentum are conserved. This means that after the collision, the total kinetic energy and total momentum of the system remains the same as before the collision.
2. How do you solve a 2D Elastic Collision problem?
To solve a 2D elastic collision problem, you will need to use the principles of conservation of momentum and conservation of kinetic energy. This involves setting up equations for the initial and final momenta and kinetic energies of the objects involved, and solving for the unknown variables using algebraic methods.
3. What is the difference between elastic and inelastic collisions?
In an elastic collision, both kinetic energy and momentum are conserved. This means that the objects involved bounce off each other without any loss of energy. In an inelastic collision, some kinetic energy is lost and converted into other forms of energy such as heat or sound. Momentum is still conserved in inelastic collisions, but kinetic energy is not.
4. Can a 2D Elastic Collision problem be solved without using equations?
No, a 2D elastic collision problem cannot be solved without using equations. The principles of conservation of momentum and kinetic energy require mathematical equations to be set up and solved in order to find the unknown variables.
5. What are some real-world examples of 2D Elastic Collisions?
Some real-world examples of 2D elastic collisions include billiard balls colliding on a pool table, two cars colliding head-on and bouncing off each other, and a tennis ball bouncing off a racket. These examples demonstrate the conservation of both momentum and kinetic energy during the collision.
