• Support PF! Buy your school textbooks, materials and every day products via PF Here!
2D kinematics - find angle
  • Thread starter rogers236
1. Homework Statement
A sniper barrel is exactly one meter above the ground and perfectly horizontal. 1000m away is a target one meter above the ground. if the bullet leaves the gun with a muzzle velocity of 1500m/s will it reach the target? (no, next part is my problem) at what angle should the sniper shoot to hit the target?
[tex]\Delta[/tex]x = 1000m
[tex]\Delta[/tex]y = 0m
ax = 0
ay = -9.8m/s2 (gravity)
V0x = ?
V0y = ?
time (t) = ?
angle [tex]\theta[/tex] = ?
V0 = 1500m/s
2. Homework Equations
[tex]\Delta[/tex]X = v*t
[tex]\Delta[/tex]V = V - V0 = a*t
[tex]\Delta[/tex]X = (1/2)*a*t2 + V0*t
V2 = 2*a*[tex]\Delta[/tex]X - V02
V0x = V0*cos[tex]\Theta[/tex]
V0y = V0*sin[tex]\Theta[/tex]
*the first four equations can be used for either the X or Y dimension; [tex]\Delta[/tex]X will just change to [tex]\Delta[/tex]Y
3. The Attempt at a Solution
I'm not looking for the answer, just a point in the right direction please.
For part one of the question, I found that it would take the bullet 2/3 of a second to reach the target in the X dimension. But in that same time, it would fall 2.2m, hitting the ground 322.3m from the target.
Thanks for the reply. I checked out that link and then fixed my original post a bit, putting in the equations as I learned them.
LowlyPion
3,079
Now you need to figure the time it will be in the air as a function of the vertical velocity. Up and down.
Then figure the same time as a function of the horizontal velocity and the known distance. These times of course must be equal, so that begins to put you in position to figure out what angle satisfies both conditions.
I've done that and get:
(-2V0y)/(-9.8) = Time-y
1000/V0x = Time-x
then to
((-9.8)1000)/V0x = -2V0y
((-9.8)1000)/(1500cos[tex]\Theta[/tex]) = -2(1500)sin[tex]\Theta[/tex]
((-9.8)1000) = -2(1500)sin[tex]\Theta[/tex](1500cos[tex]\Theta[/tex])
((-9.8)1000) = (-2)(1500)(1500)sin[tex]\Theta[/tex]cos[tex]\Theta[/tex]
((-9.8)(1000))/((-2)(1500)(1500)) = sin[tex]\Theta[/tex]cos[tex]\Theta[/tex]
0.00217777778 = sin[tex]\Theta[/tex]cos[tex]\Theta[/tex]
Now what?
LowlyPion
3,079
You might want to recognize the identity
2SinθCosθ = Sin2θ
It's a terrifically useful trig identity that you may run into again with projectile motion equations.
Related Threads for: 2D kinematics - find angle
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
