Can You Calculate the Required Brick Throwing Velocity to Hit a Moving Target?
In summary, you throw a brick at an angle of 45 degrees above the horizontal so that it hits the top of the trash pile when the truck is 30 meters away from the building.
nice4life
You are on the top of a 100m high (approximately 30 story) building. You just finished building a brick grill so the tenants of the building can have barbecues. You have one brick left and do not want have to lug it back off the roof. Luckily, you see a garbage truck with its roof open (top of trash pile is 2m above the road) coming down a road that passes by the building. The road is 30m from the building at closest approach. The truck is moving down the road with constant velocity 15m/s. You need to make sure you hit the trashpile, or someone is going to get hurt. You can throw the brick comfortably at an angle of 45◦ above the horizontal.
(a) What velocity do you need to throw the brick so that it hits the top of the trash pile
when the truck is 30m away from the building? Does this sound like you could do it?
deltax=Vox*t+1/2at^2 Vox = Initial velocity on x dimension.
Vy = Voysin0
Vx = Voxcos0
I understand that I need Voysin0 and Voxcos0, but don't have Vo for x or y.
delta x = 30m and i think deltay = 98m because the truck is 2m about ground from the 100m building.
since on x axis/dimension accel. is constant 0. deltaX=Vox*t+0 but i don't know Vox.
Because they did not give me an initial velocity I am finding it very difficult to get this started. How do I find the Vsin0 and Vcos0 without relevant velocities?
  • eqnsheet.pdf
hello nice4life!
welcome to PF!
here, you are given the angle of throw = 45degree
and range is 30m.
vertical distance = 98m
so suppose initial velocity is V. so Vcos45.t = range, t = time of flight.
and Vsin45 is vertical component of velocity, use the equations of motions to calculate the time of flight, which is the time to get down 98m to the pile.
so solve two equations and you will get V.
Thank you for the welcome, I am delighted I found this site.:smile:
so while i was working it all out i got t=5.11 and Vintial=8.3
i found this by two assumptions, 1) that Vcos45 and Vsin45 are the same 2) that it would take the same time for the brick to reach 30m distance and 98m high.
so i used
detlax=Vcos[tex]\Theta[/tex]*t
30m=Vcos45*t
and
deltay=Vsin[tex]\Theta[/tex]*t+1/2(a)t^2
98m=Vsin45*t+1/2(9.8)t^2
then set
Vcos45=30/t
plug it in
-98=(30/t)t-1/2(9.8)t^2
ALGEBRA...
t=5.11sec (i was happy when i got this :smile:)
So then
Vintital=(30/cos45*5.11)=8.3m/sdoes this seem right? Please may I get a tiny hint as to what I should do from here?
you should use
98m=Vsin45*t - 1/2(9.8)t^2 instead of +
i have worked it out a million times and i keep getting error. is delta y 98 or -98.
its - 98
What is a 2D kinematics problem?
A 2D kinematics problem is a type of physics problem that involves analyzing the motion of an object in two dimensions, typically in the x and y directions. This includes calculating the displacement, velocity, and acceleration of the object, as well as determining the path it takes.
What are the key equations used in solving 2D kinematics problems?
The most frequently used equations in 2D kinematics problems are the equations of motion, which include:
- x = x0 + v0t + 1/2at2
- v = v0 + at
- v2 = v02 + 2a(x-x0)
- x = x0 + (v0+v)/2 * t
Where x is the displacement, x0 is the initial position, v is the final velocity, v0 is the initial velocity, a is the acceleration, and t is the time.
How do you approach solving a 2D kinematics problem?
To solve a 2D kinematics problem, you should first identify the known and unknown variables, and then use the appropriate equations to solve for the unknowns. It is important to carefully label and draw a diagram of the problem, and also pay attention to the units of measurement being used.
What are some common mistakes made when solving 2D kinematics problems?
Some common mistakes made when solving 2D kinematics problems include:
- Not carefully labeling and drawing a diagram of the problem
- Using the wrong units of measurement
- Forgetting to account for the direction of motion
- Not using the correct equation for the given scenario
- Making calculation errors
To avoid these mistakes, it is important to double check your work and approach the problem systematically.
How can 2D kinematics problems be applied in real life?
2D kinematics problems can be applied in many real life scenarios, such as calculating the trajectory of a projectile, determining the motion of a car on a curved road, or analyzing the motion of a roller coaster. They are also important in fields such as engineering, sports, and transportation, where understanding and predicting the motion of objects is crucial.
10K
