2D Momentum
  1. Oct 29, 2016 #1
    A hockey puck of mass 0.16kg has initial velocity of 2.0m/s[E] and collides with another puck that is initially at rest, has mass of 0.17kg. Once they collide the first puck travels 1.5m/s[N 31 E]. Find final velocity of second puck.
    2. Relevant equations
    3. The attempt at a solution
    I keep getting an answer that does not match with solutions.
    So I first drew it out then made a triangle that does is not a right angle, so I decided to use cosine law.
    I am aware that my total momentum is 0.32 kg m/s because PT=PT' ...
    PT= (0.16)(2)
    =0.32 kg m/s
    I also figured out my P1
    P1= (0.16)(1.5)
    = 0.24 kg m/s
    I set my triangle up to have a 59° because 90°-31°.
    Now I use cosine law to find opposite side of my 59°.
    a=√(0.32)2+(0.24)2-2(0.24)(0.32)cos59
    P2= 0.2844 kg m/s
    Now I plug this into P=mv
    V = 0.2844/0.17
    V = 1.7m/s [E 46 S]
    Did I do something wrong??
  3. Oct 29, 2016 #2
    I worked this problem pretty quickly so like all of my solutions, I don't have a lot of confidence in it. But I got the same answer as you did. Maybe we both did it wrong the same way, or possibly the solution is wrong. Hopefully someone else will chime in.
    Edit: I just worked the problem a second time and got the same result.
  4. Oct 29, 2016 #3
    haruspex
    I get the same. Do you know what the answer is supposed to be?
  5. Oct 30, 2016 #4
    1.8 m/s. Which is close but usually the answer I get is the exact same as solutions.
  6. Oct 30, 2016 #5
    haruspex
    I got 1.67, so 1.8 definitely seems wrong. Equal masses gives 1.77.
    I tried swapping the masses but it made the answer 1.88.
    I varied the angle from 31 degrees. Had to take it down to about 25 to get 1.8m/s. (The second puck's angle was then 45 degrees S of E.)
  7. Oct 30, 2016 #6
    @haruspex, I think you're right that they probably solved it using the same mass for both pucks.
Have something to add?
Draft saved Draft deleted
Similar Discussions: 2D Momentum
  1. 2D momentum (Replies: 5)
  2. 2D Momentum Problem (Replies: 7)
  3. 2D Momentum Problem (Replies: 2)
  4. Momentum 2d (Replies: 2)
  5. 2D Momentum Collision (Replies: 13)
Loading...
