How Far Does the Arrow Fall Short of the Target?
In summary, the problem involves an arrow being fired with a horizontal speed of 89 m/s at a target 60 m away. The arrow is initially 1 m above the ground. To find how far short of the target it falls, a table is set up with the horizontal and vertical values. However, more information is needed to solve the problem, such as the time it takes for the arrow to reach the target and the correct use of positive and negative signs for acceleration and vertical distance. The final answer is 20 m short of the target.
chrozer
An arrow is fired with a horizontal spped of 89 m/s directly at a target 60 m away. When it is fired, the arrow is 1 m above the ground. How far short of the target is it when it strikes the ground?
D = vt
D = Vit + (1/2)at2
Vf = Vi + at
Vf2 = Vi2 + 2ad
Basically my teacher says to set up a table, one side horizontal values and the other vertical values.
The values I know for:
  • Horizontal - velocity = 89, distance = 60
  • Vertical - acceleration = -9.8, distance = 1
Then that is where I get stuck...help? BTw the anser is 20 m short, but my teacher wants me to show work.
There are some more items to fill out in your table.
Horizontal: time?
Vertical: time?
Also, there are a couple of problems with the values you do have.
1. If the arrow falls short of the target, it does not go the full 60m distance.
2. Acceleration is -9.8 m/s^2, so you are using upward=positive, downward=negative. But then you say the vertical distance traveled is +1m upward. Gotta watch those +/- signs.
I would approach this problem by first identifying the known values and variables, and then applying the relevant equations to solve for the unknown variable.
Known values:
- Horizontal velocity (Vi) = 89 m/s
- Horizontal distance (D) = 60 m
- Vertical acceleration (a) = -9.8 m/s^2
- Starting vertical distance (Vi) = 1 m
Unknown variable:
- Horizontal distance at impact (Df)
Using the equation D = vt, we can first solve for the time it takes for the arrow to reach the target:
60 m = 89 m/s * t
t = 0.674 s
Next, we can use the equation D = Vit + (1/2)at^2 to solve for the final vertical distance (Df):
Df = 1 m + (89 m/s * 0.674 s) + (1/2 * -9.8 m/s^2 * (0.674 s)^2)
Df = 1 m + 59.986 m - 2.323 m
Df = 59.663 m
Since the arrow started at a height of 1 m and landed at a final vertical distance of 59.663 m, it has traveled a total vertical distance of 58.663 m before hitting the ground. This means it fell 58.663 m in 0.674 s.
Using the equation Vf = Vi + at, we can solve for the final vertical velocity (Vf) at impact:
Vf = 89 m/s + (-9.8 m/s^2 * 0.674 s)
Vf = 82.3 m/s
Now, using the equation Vf2 = Vi2 + 2ad, we can solve for the final horizontal distance at impact (Df):
0 = (89 m/s)^2 + 2 * (-9.8 m/s^2) * Df
Df = -801.8 m / (-19.6 m/s^2)
Df = 40.9 m
Since the target is 60 m away, and the arrow has traveled a horizontal distance of 40.9 m before hitting the ground, it is 60 m - 40.9 m = 19.1 m short of the target.
Therefore, the final answer is that the arrow falls
What is 2D motion?
2D motion refers to the movement of an object in two dimensions, typically represented by the x and y axes. This means that the object is moving in both the horizontal and vertical directions.
What is a physics problem?
A physics problem is a question or scenario that requires the application of principles and concepts from the field of physics to solve. It typically involves using mathematical equations and formulas to analyze and understand the behavior of objects and their motion.
How do you solve a 2D motion physics problem?
To solve a 2D motion physics problem, you first need to identify the given information such as initial and final positions, velocities, and acceleration. Then, you can use equations such as the kinematic equations or vector analysis to solve for the unknown variables. It is important to draw a diagram and label all the known and unknown values to help visualize the problem.
What are some common types of 2D motion physics problems?
Some common types of 2D motion physics problems include projectile motion, circular motion, and motion on an inclined plane. These problems typically involve analyzing the motion of an object in two dimensions, with or without the influence of external forces such as gravity or friction.
What are some real-life applications of 2D motion physics?
2D motion physics has many real-life applications, such as predicting the trajectory of a ball thrown by a baseball pitcher, calculating the speed and direction of a satellite in orbit, and analyzing the motion of a rollercoaster on a track. It is also used in fields such as engineering, architecture, and sports to design and optimize structures and movements.
