2nd moment of area + centroid
rock.freak667
6,230
31
I need to get the centroid of this shape
http://img713.imageshack.us/img713/5607/section.jpg [Broken]
it's a semi-circular section basically. On the left most side, the distance from the origin to to where it cuts the y-axis is 'R' and the distance from the x-axis to the end of the upper arc is 'r'.
[tex]I_x = \int y^2 dA[/tex]
[tex]I_y= \int x^2 dA[/tex]
[tex]A \bar{x}= \int xy dA[/tex]
[tex]A \bar{y} = \int y dA[/tex]
I just need to know if my integrals are set up properly
The equation of the entire circle would have been x2+y2=R2.
[tex]A= \int y dx = \int_{0} ^{r} \sqrt{R^2-x^2}[/tex]
Assuming my 'A' is correct
dA=y dx
[tex] A \bar{x} = \int xy dA = \int xy^2 dx = \int_{0} ^{r} x(R^2-x^2) dx[/tex]
my object is symmetrical about the x-axis so [itex]\bar{y} = 0[/tex]
[tex]I_x = \int y^2 dA = \int y^3 dx = \int_{0} ^{r} (R^2-x^2)^{\frac{3}{2}}dx[/tex]
[tex]I_y = \int x^2 dA = \int x^2 y dx = \int_{0} ^{r} x^2\sqrt{R^2-x^2)dx[/tex]
I think my limits may be wrong, but the integrands should be correct.
Also, if someone can just link me to a site with the centroid and second moment of area of this shape that would be helpful as I don't need to actually derive it in my report, I just need to use the result.
Answers and Replies
LCKurtz
Insights Author
766
Typo you forgot the dx.
dA=y dx
These look OK.
This one is wrong. If you set it up as this double integral
[tex]\int_0^R\int_{-\sqrt{R^2-x^2}}^{\sqrt{R^2-x^2}} y^2\ dydx = 2\int_0^R\int_{0}^{\sqrt{R^2-x^2}} y^2\ dydx[/tex]
and work the inner integral, you will see why.
and the last one is OK.
rock.freak667
6,230
31
thanks very much, I will have to recheck the double integral one.
rock.freak667
6,230
31
I need to also find the mass moment of inertia of that section if it were rotated about the x-axis.
I assumed an elemental section such that x2+y2=R2
dI= y2 dm =y2 ρ dV = ρ y2 (πy2 dx) =ρπy4dx.
[tex]I = \rho \pi \int_{0} ^{r} (R^2 -x^2)dx[/tex]
is this correct? This somehow gives me answers like 2400 kgm2 (ρ=7850 kg/m3) with the total integrand being like 0.9. The section is very small in fact and is hollow, I don't think it should be that much.
Related Threads on 2nd moment of area + centroid
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
