3.3v cmos
likephysics
636
Why is the CMOS logic voltage exactly 3.3V, why not 3V or 3.5V?
Answers and Replies
Fish4Fun
247
"Logic Families" (http://en.wikipedia.org/wiki/Logic_family) are typically built for compatibility and involve "standards". A particular family generally employs identical silicon level transistors to perform a wide range of functions. Designing a die component requires considerable engineering, so it makes sense to reuse them.
A "new" generation is typically designed with specific goals in mind, including, but not limited, to backward compatibility, lower power consumption, faster response time, higher bandwidth and smaller die area. In most cases 3.3V logic can interface with 5V logic, but consumes less power, is faster and has a smaller die. 3.3V is certainly not the lowest voltage CMOS logic family, 2.5V and 1.7V logic are quite common in high density, high-speed ICs like RAM and Processors.
I hope that helps answer your OP.
Fish
likephysics
636
Fish
Basically, if its not 3.3v then it wouldn't be compatible with 5v TTL?
Fish4Fun
247
It is a bit more complicated than that. You might have a look here:
http://www.interfacebus.com/voltage_threshold.html
for the actual voltage thresholds of various families of ICs.
From the article referenced above:
By lowering the power supply from 5V to 3.3V, switching power was reduced by almost 60 percent (power dissipation is proportional to the square of the supply voltage).
3.3V devices typically have supply ranges from 3V or less to 3.6V or more, so it is not so much that it is exactly 3.3V, but rather that 3.3V is more like the "target voltage".
Fish
Suggested for: 3.3v cmos
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
