Can Alternative Mathematical Expressions Improve ABS() and Round() Functions?
  • Thread starter 128GB
In summary, the Math for ABS(), Round(), and related functions can be inefficient and prone to errors.
128GB
3 Simple questions -- Math for ABS(), Round()
To find the absolute value of a number you can use this
((x ^ 2) ^ 0.5)
To round a number up you can use this
-(((-x - 1) - ((-x - 1) % 1)) + 1)
To round a number down
(x - (x % 1))
Are there better ways to do this? The middle one is the one I'm thinking should somehow be shorter
This is for a program I'm making so it needs to be in normal text format please
Technology news on Phys.org
((x ^ 2) ^ 0.5)
Not unless you want to possibly get errors. Since computers have a limited number of bits to work with, there will be numbers for which x is NOT equal TO (x^2)^.5 due to rounding errors
Come to think of it, your other formulas might have the same flaw although probably with fewer manifestations.
I just use the intrinsic functions in whatever language I'm programming it. I figure the compiler writers probably got it done as well as I'll be able to.
((x ^ 2) ^ 0.5)
In addition to the precision problem noted by phinds, this is also a terribly inefficient way to calculate the absolute value of a number. Squaring requires a multiplication, and the square root is far worse. Either use the built-in operator or, if there isn't one, then provide a simple one. An implementation in C++ could look like
Code:
double abs_d(double x)
    if (x >= 0)
        return x;
    else
        return -x;
If you declare it inline, then it should be about as efficient as you're going to get.
For the rounding operations, note that the "% 1" operation could be expensive depending on how the compiler implements it. It might also give the wrong result for negative numbers, depending on the language. Check whether your language/library provides floor and ceil functions; no point reinventing the wheel. These functions are more likely to get all the IEEE floating point corner cases right, and they may give you access to floating point hardware instructions if available.
I do have reasons for "reinventing the wheel" because I am modifying them, I wanted to use the actually math not
if x >= 0 then
return x
else
return -x
end --This is lua by the way
I wanted to recreate the math library for modifying
if I did it like that instead of the math for abs, then I couldn't just copy paste the same function with a different math problem to create floor and ceil
#define abs(x) ((x<0)?-x:x)
But use the library.
This fails due to unintended side effects if someone writes something like y = abs(++x). Both x and y will have the wrong values after this invocation.
It doesn't even work for y = abs(x) if x and y are complex numbers.
And don't even try to understand the error message(s) you might get if x is a user-defined type!
Actually, it even fails for something like abs(-1) since the macro didn't use enough parentheses. So abs(-1) expands as
(-1<0)?--1:-1
which is a syntax error.
(-1<0)?--1:-1
Unless you have a compiler bug, and --1 evaluates to -2. :devil:
Excuse my ignorance (and allow me to play Devil's Advocate, if I can make sense)
I don't quite understand your problem or your request, you say "Math for Abs() and Round()"; but, what exactly do you call math? I mean, you are using basic math operators, alright, but you are also using %...so, what's wrong with using abs()? What if programmers had used the single non-alphabetic character "|" to express the unary "operator" absolute value of a number, |x ? would you be looking for a mathematical expression for it, too, then? Or would you be content with it?
Have you looked into how abs() is typically implemented, in the first place?
Is it done mathematically? I presume not, otherwise you wouldn't be asking?
So, who is to say that every mathematical function can be expressed mathematically, whatever that means?
I mean, it is not like every function is simply a short hand or abbreviation for some purely mathematical expression. is it?
By the way, what exactly you are planning of implementing again? As mention before, your expressions may not evaluate well under certain conditions...how about working with integers? what are you going to do with the result from ^0.5 ? How are you going to know that you need to return an integer? and are you going to round up or down? what's the result? 1.9999? 2.00001?
Another "by the way", have you tried defining your own abs() function? I once had Fortran function called pow() (it is not an intrinsic in Fortran) just to realized that is was somehow over writting the 'behind-the-scenes' C-function pow() that apparently was being used to implement Fortran's exponentiation operation '**'
What I am trying to say, in the previous paragraph, is that you may find that you can simply put your own functions in front of the intrinsic ones and you are done. Is this not good enough? does it not accomplish what you want?
Anyway, just asking questions as I feel the problem was not fully constraint in my opinion.
gsal
1. What is ABS() in math?
In math, ABS() stands for absolute value. It is a function that returns the distance between a number and zero on a number line. This distance is always positive, regardless of the original number's sign.
2. How do you use ABS() in math?
To use ABS() in math, you simply need to input a number within the parentheses. For example, ABS(-5) will return the absolute value of -5, which is 5. This function is commonly used in finding the magnitude or distance in various mathematical equations.
3. What is the purpose of rounding in math?
Rounding in math is used to simplify numbers and make them easier to work with. It involves changing a number to the nearest whole number, decimal place, or significant figure. Rounding is especially useful when dealing with large numbers or when precision is not necessary.
4. How do you round a number using the Round() function?
To round a number using the Round() function, you need to input the number you want to round and the number of decimal places you want to round to within the parentheses. For example, Round(3.14159, 2) will round the number 3.14159 to 2 decimal places, giving you 3.14 as the result.
5. Can ABS() and Round() be used together in math?
Yes, ABS() and Round() can be used together in math. For example, ABS(Round(-2.5)) will first round the number -2.5 to the nearest whole number, which is -3. Then, ABS() will return the absolute value of -3, giving you a final result of 3. This combination of functions is commonly used in math to ensure that the final value is always positive.
