What is the Speed of M2 at 1.45 s After Release of Three Sliding Masses?
In summary: I'm sorry.I don't understand what you are asking.Please provide more information.After you draw your FBDs, you will have a system of 3 equations.SigmaF = T_{1,2} - m_{1}g = m_{1}aSigmaF = T_{2,1} + m_{2}g - m_{2}g + T_{2,3} = m_{2}aSigmaF = -T_{3,2}+m_{3}g = m_{3}a
cassienoelle
63
The three blocks shown are relased at t=0 from the position shown in the figure. Assume that there is no friction between the table and M2, and that the two pulleys are massless and frictionless. The masses are: M1 = 1.0 kg, M2 = 7.0 kg, M3 = 3.0 kg.
Calculate the speed of M2 at a time 1.45 s after the system is released from rest.
(M1 is on left side of box, M2 is on the top of the box, M3 is on the right side of the box. Corners of box are pulleys.)
None.
I have ZERO clue.
None.
I have ZERO clue.
These problems are always very interesting ones.
First, you have to draw a FBD for all three masses.
Where is the figure? :confused:
https://s3.lite.msu.edu/res/msu/physicslib/msuphysicslib/09_Force_and_Motion/graphics/prob81_pulley2_3m.gif
There is no image present relevant to the question.
So basically, there are two pulleys attached to the box.
There is a single, massless string run through the pulley system.
M1 is hanging on the left side of the box and M3 is hanging on the right side of the box (attached to string I presume).
M2 has a string connected on both sides? Yes?
The image should be 3boxes on a pulley system.
Yes, Aggression, that is right.
Is that a university website or something like that?
If so, i think i can't access that until i am a student of it.
Alright, now we can get this problem started.
So, you'll have 3 separate FBDs.
M1's FBD will have a T force going up and a Weight Force going down.
M2's FBD will have tension forces on both sides, a normal force going up that is equal to a weight force going down.
M3's FBD will have a T force going up and a weight force going down.
Someone correct me if I'm wrong.
Image should be attached.
None.
I have ZERO clue.
consider the 3 masses plus string as a single sytem, with the pulleys just adjusting a couple of directions.
The Force trying to move the system clockwise is the weight of the right hand mass.
The force trying to move the system in the anti-clockwise direction is the weight of the left hand mass.
One of those is bigger and "wins".
The net force [one weight minus the other] acts on the whole system. F = ma is then used.
But i don't have the acceleration of the force...
PeterO, please don't directly come on F=ma relation. It would be better if you help the OP make equations for each body. :smile:
Okay, can you give me a hint please?
I'm sorry, but I'm really bad at physics and I'm stressed and Idk where to go.
Well, after you draw your FBDs, you will have a system of 3 equations.
So, sum the forces in each situation.
We will denote T[itex]_{1,2}[/itex] as the tension force between the M1 and M2 object.
We will denote T[itex]_{2,3}[/itex] as the tension force between the M2 and M3 object.
T[itex]_{2,1}[/itex] = T[itex]_{1,2}[/itex]
T[itex]_{3,2}[/itex] = T[itex]_{2,3}[/itex] By Newton's 3rd law.
Now, sum of the forces for M1...
[itex]\Sigma[/itex]F = T[itex]_{1,2}[/itex] - m[itex]_{1}[/itex]g = m[itex]_{1}[/itex]a
Sum of the forces for M2...
[itex]\Sigma[/itex]F = - T[itex]_{2,1}[/itex] + m[itex]_{2}[/itex]g - m[itex]_{2}[/itex]g + T[itex]_{2,3}[/itex] = m[itex]_{2}[/itex]a
Sum of the forces for M3...
[itex]\Sigma[/itex]F = -T[itex]_{3,2}[/itex]+m[itex]_{3}[/itex]g = m[itex]_{3}[/itex]a
I'm not 100% sure that these are correct. Someone double check me.
MEH! I have no clue!
Let's assume they are. haha
Now, add up all the equations. The tension forces will cancel leaving you with...
[itex]\Sigma[/itex]F = m[itex]_{3}[/itex]g - m[itex]_{1}[/itex]g = m[itex]_{1}[/itex]a + m[itex]_{2}[/itex]a + m[itex]_{3}[/itex]a
So, factor out a g from the left side, and an a from the right side...
g(m[itex]_{3}[/itex]-m[itex]_{1}[/itex]) = a(m[itex]_{1}[/itex] + m[itex]_{2}[/itex] + m[itex]_{3}[/itex])
Solve for a and that will give you the acceleration of each block.
m1 = 1.0 kg
m2 = 7.0 kg
m3 = 3.0 kg
where did m2g go?
m2g canceled out because the equation for M2 included...
m2g - m2g = 0
So, that's why they canceled out.
It doesn't matter, i timesed that by the time and i got the answer :d
1. What is the concept behind "3 Sliding Masses; find speed"?
The concept behind this problem is to calculate the speed of three masses that are sliding on a frictionless surface, given their masses, initial positions, and final positions.
2. How do you solve for the speed of the sliding masses?
To solve for the speed, you can use the conservation of energy principle, which states that the total energy of a system remains constant. In this case, the initial kinetic energy of the masses will be equal to the final kinetic energy, allowing you to calculate the speed using the mass and distance measurements.
3. What are the key equations used in this problem?
The key equations used in this problem are the conservation of energy equation, which states that the total energy is equal to the sum of kinetic and potential energies, and the formula for kinetic energy, which is 1/2 * mass * velocity^2.
4. Can this problem be solved without using the conservation of energy principle?
Yes, this problem can also be solved using the equations of motion, such as the equation for constant acceleration or the equation for average velocity. However, using the conservation of energy principle is often the most efficient and accurate approach.
5. What are some real-world applications of this problem?
This problem can be applied to various scenarios, such as calculating the speed of a rollercoaster or a car moving down a hill, determining the velocity of particles in a chemical reaction, or analyzing the motion of objects in space.
