3D Dirac Delta Function
  • Thread starter cordyceps
Griffiths' section 1.5.3 states that the divergence of the vector function r/r^2 = 4*Pi*δ^3(r). Can someone show me how this is derived and what it means physically? Thanks in advance.
gabbagabbahey
First, use the divergence theorem to show that [tex]\int_{\mathcal{V}}( \vec{\nabla}\cdot\frac{\hat{r}}{r^2})d\tau=4\pi[/tex] for any surface enclosing the origin (use a spherical surface centered at the origin for simplicity).
Then, calculate the divergence explicitly using the formula on the inside of the front cover for divergence in spherical coords. You should find that it is zero everywhere except at the origin where it blows up (because the 1/r terms correspond to dividing by zero).
Finally, put the two together by using eq 1.98 with [tex]f(\vec{r})\delta^3(\vec{r})\equiv \vec{\nabla}\cdot\frac{\hat{r}}{r^2}[/tex]
As for a physical interpretation, there really isn't one (although there are physical consequences as you'll see in chapter 2 and beyond); but there is a geometric interpretation....if you sketch the vector function [tex]\frac{\hat{r}}{r^2}[/tex] (figure 1.44 in Griffiths) you'll see why there must be an infinite divergence at the origin. This is all discussed in section 1.5.1
Sorry, I'm kinda slow- why does LaTeX Code: f(\\vec{r})\\delta^3(\\vec{r})\\equiv \\vec{\\nabla}\\cdot\\frac{\\hat{r}}{r^2}?
Can't use latex. Why does f(R)δ^3(R) = the divergence of R/r^2?
gabbagabbahey
The fact that the divergence of [tex]\frac{\hat{r}}{r^2}[/tex] is zero everywhere, except at the origin where it is infinite, but when integrated gives a constant, means that it must be some unknown normal function [itex]f(\vec{r})[/itex] times a delta function so, you call it [itex]f(\vec{r})\delta^3(\vec{r})[/itex] and solve for [itex]f[/itex] by setting the integral (eq. 1.98) equal to the value you calculated using the diverergence theorem ([itex]4\pi[/itex])
Ok. I think I got it. Thanks a lot!
Related Threads for: 3D Dirac Delta Function
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
