3D Visualization of Temperature Distribution Function
In summary, I just downloaded scilab and I don't know how to plot the function I'd like. I've found the temperature distribution of a 2 dimensional system. I want to visualize this function in 3d. I've read the help file of scilab of how to plot but I'm getting lost very quickly. Any help is appreciated!
fluidistic
261
I just downloaded scilab because Wolfram Alpha wouldn't want to plot the function I'd like.
In a physics problem I've found the temperature distribution of a 2 dimensional system. I'd like to visualize this function in 3d.
The function I want to plot is [itex]u(x,y)=\frac{1}{\pi} \arctan \left ( \frac{y+a}{x} \right )+\frac{1}{\pi} \arctan \left ( \frac{a-y}{x} \right )[/itex]. I've read the help file of scilab of how to plot but I'm getting lost very quickly. Any help is appreciated!
Edit: so far I have
Code:
x=[0:0.1:12]'; y=[0:0.1:12]'; z=atan((y-2)/x)+atan((2-y)/2); plot3d(x,y,z)
. I don't know how to pass a line (enter just evaluates the command I wrote). I get the message "Inconsistent addition."
Don't know scilab, but your second 'atan' has a '2' in the denominator...shouldn't that be 'x'?
what do the single apostrophes do?
what do you think you are accomplishing with z=... ? are x and y traversed independently as if they were in 2 nested do-loops...or is it just a one-to-one? In other words, is z also just a vector? or are you getting a matrix?
try to input one line at a time and find out what you get back after each...don't jump all the way to plotting...baby steps, baby steps!
No problem. Yes, it should be an x.
I have absolutely no idea. Probably a necessary part of syntax.
Hmm, I wanted it to be a function of both x and y and then plot it. My u(x,y)
Ok.
Here is an example they give, from which I've been inspired:
Code:
// simple plot using z=f(x,y)
t=[0:0.3:2*%pi]';
z=sin(t)*cos(t');
plot3d(t,t,z)
Edit: It seems that x=[0:0.1:12] is a matrix or so. I thought it would plot x from 0 to 12 with increment of 0.1. Sigh. I really have no idea about Scilab.
ok, so, did the example work? Did you get a surface plot?
I think the apostrophe means transpose. In the example where they multiply sin times cos, notice how they pass t to one function and t' to the other...the fact that these two vectors are orthogonal (one is a column vector and the other a row vector) may be what makes it produce a square matrix for z...in other words, the expression is evaluated as in a double loop.
So, go back to your own problem and pass y and x' and see what you get...see if you can display the z matrix before plotting to see if in fact is a square matrix.
look at the function meshgrid if it exists in scilab (it is a MATLAB function), you need a 2-d grid to properly plot in 3-d
I tried:
Code:
-->x=[0:0.1:12]';
-->y=[0:0.1:12]';
-->z=atan((y-2)/x)+atan((2-y)/x);
-->plot3d(x,y,z)
I do get a 3d surface but it's all flat.
In analogy to their working example:
Code:
x = -1:0.1:1;
y = -1:0.1:1;
[X,Y] = meshgrid(x,y);
for i=1:size(X,1)
  for j=1:size(X,2)
    Z(i,j) = sinc(2*%pi*X(i,j)*Y(i,j));
  end
end
surf(X,Y,Z)
I do:
Code:
-->x = 1:0.1:12;
-->y = 1:0.1:12;
-->[X,Y] = meshgrid(x,y);
-->for i=1:size(X,1)
-->  for j=1:size(X,2)
-->    Z(i,j) = atan((Y(i,j)-2)/X(i,j))+atan((2-Y(i,j))/X(i,j));
-->  end
-->end
-->surf(X,Y,Z)
And I still get a totally planar surface.
I think the reason you are getting a flat surface is because you have yet another typo which effectively makes the summation be zero...
in your numerators, you have Y-2 and 2-Y ...you should have Y+2 and 2-Y
and, for completeness, you may want to put back the division by PI
Whoops you're right. Well since I took a=2 while it's totally arbitrary, I don't think the 1/pi factor is really relevant.
Using the meshgrid I get a somehow decent surface, but doesn't work well for the plot3d command so far.
Here are 2 screenshots.
Hhhmm...here it is what it looks like with python and matplotlib.
Maybe it's the same. If you take a=2, I suggest you to reduce the box up to y and x=6 rather than 12.
1. What is 3D visualization of temperature distribution function?
3D visualization of temperature distribution function is a technique used to represent the distribution of temperature in a three-dimensional space. It allows scientists to visualize and analyze the temperature variations in a given area.
2. How is 3D visualization of temperature distribution function useful?
3D visualization of temperature distribution function is useful in many scientific fields, such as meteorology, climatology, and environmental science. It helps researchers to better understand temperature patterns and changes in different environments.
3. What data is needed for 3D visualization of temperature distribution function?
To create a 3D visualization of temperature distribution function, data is needed from various sources such as weather stations, satellites, and climate models. This data includes temperature measurements at different locations and times.
4. How is 3D visualization of temperature distribution function created?
3D visualization of temperature distribution function is created using specialized software that can process and analyze large amounts of data. The software uses algorithms to generate a 3D representation of temperature distribution based on the data input.
5. What are the benefits of using 3D visualization of temperature distribution function?
3D visualization of temperature distribution function allows for a more comprehensive understanding of temperature patterns, which can aid in predicting weather patterns, identifying areas of high and low temperatures, and monitoring changes in temperature over time. It also allows for easier communication and interpretation of complex temperature data.
  • MATLAB, Maple, Mathematica, LaTeX
