3d - Vector question
  • Thread starter soandos
where is the flaw in the following:
it is possible to define a 3d vector using the form:
(x,y,z) = (x_1,y_1,z_1)+t(a,b,c)
this can then be parameterized to become
x = x_1 + a*t
y = y_1 + b*t
z = z_1 +c*t
so, for example, given the vector (x,y,z) = (1,2,3) + t(5,6,7)
one can parametrize it to become:
x = 1 + 5t
y = 2 + 6t
z = 3 + 7t
solving the first equation for t gives
t = (x-1)/5
plugging that into the other two equations gives:
y = 2 + 6/5 * (x-1)
z = 3 + 7/5 * (x-1)
solving the second one for x gives:
x = (5*z-8)/7
changing y = 2 + 6/5 * (x-1) to y = 2 + 6/5 * (2x-x-1)
and in the -x spot putting -(5*z-8)/7 yeilds:
y = 2 + 6/5 * (2x-(5*z-8)/7-1)
simplifying gets:
76 = 35 y + 30 z - 84 x
which is the equation of a plane.
this cannot possibly be right as i started out with a 2-d object (the vector)
where did i mess up?
(p.s. i tried to do all of this algebraically but it got too ugly for me)
thanks.
Answers and Replies
djeitnstine
First of all, that is not the equation of a vector, it is a vector equation of a line.
In that equation there exists 2 vectors, the position vector r and direction vector v
so in your example
r = <1,2,3>
v = <5,6,7>
so your line starts at (1,2,3) and points in the direction <5,6,7>
sorry if i used the wrong words. the fact remains that i began with a line/line segment/vector and ended up with an equivalent plane. this is not possible. where is the mistake?
You think you have made a mistake where you haven't (except possibly a conceptual one).
You get the equation of a plane containing the line.
Your calculations are correct. All you have done is introduced extra solutions. What you have essentially proven is that if (x, y, z) = (1, 2, 3) + t(5, 6, 7) for some t, then 76 = 35y + 30z - 84x. It, of course, is not true that if 76 = 35y + 30z - 84x, then (x, y, z) = (1, 2, 3) + t(5, 6, 7) for some t, but you haven't proven this (which is good, since it's false).
I imagine with some slight variations, you will find an equation for a different plane. However, it will still be a plane containing the original line; the two planes you found would intersect at this line.
djeitnstine
There are only 3 forms of a line in 3d. The vector, parametric and symmetric forms.
Taking your example gives:
vector form: [tex]\vec{r}=<1,2,3> + t<5,6,7>[/tex]
symmetric form: [tex]\frac{x-1}{5}=\frac{y-2}{6}=\frac{z-3}{7}[/tex]
parametric form: [tex]x = 1+5t[/tex] , [tex]y = 2+6t[/tex] , [tex]z = 3+7t[/tex]
Of course you can figure out how the line behaves in each plane (which I presume you are searching for) by solving the symmetric form gives you the trivial equation [tex]y=mx+c[/tex] on a particular plane. For example [tex]z=my+c[/tex] (zy plane) or [tex]z=mx+c[/tex] (zx plane) etc...
Edit I left out the 2 point form which looks like: [tex]\frac{x-x_{1}}{x_{2}-x_{1}}=\frac{y-y_{1}}{y_{2}-y_{1}}=\frac{z-z_{1}}{z_{2}-z_{1}}[/tex] so there are 4 (viewed at http://www.cs.fit.edu/~wds/classes/cse5255/thesis/lineEqn/lineEqn#2ptEqn)
let me try to explain:
i got three parametric equations.
i simplified them into one equation
i got the equation of a plane.
therefore, i know something went wrong.
read the PDF to see exactly what i did.
Read my post. Then read it again.
djeitnstine
adriank is correct. All you have shown is a plane that the line lies upon. There are infinitely many.
that is not the case, as i have locked it down to one plane. what happened to all of the others?
djeitnstine
I will answer you question with another, how many equations did you solve for t? I see 3 different solutions for t
Also, how many lines of the same slope and direction lie upon a single plane ?
... and by the way if you want to visualize your vectors in 3D you could use this program http://www.bodurov.com/VectorVisualizer/" [Broken]
In response to djeitnstine, i only solved one.
doe that mean anything?
show that the line containing the points (0,0,5) and (1,-1,4) is perpendicular to the line with equations:
x/7=y-3/4=z+9/3
i need help with this question..
Find vectors parallel to each line, and show that their dot product is zero.
thank you adriank:)
so;
x/7=y-3/4=z+9/3=t
solving the first equation for t gives;
x/7=t so x=7t
and other two:
y-3/4=t so y=4t+3.
z+9/3=t so z=3t-9.
u=(7,4,3) and P= (0,3,-9) is on l.
u is paralell to l.
then we find another point on l.
x=2 so y=29/7 and z= -57/7.
P1(2,29/7,-57/7)
as we have Q (0,0,5) and Q1 (1,-1,4) ; Q1-Q= (1,-1,-1).
P(0,0,-9) and P1( 2,29/7,-57/7) ; P1-P= (2,8/7,6/7)
P1P*Q1Q=2-8/7-6/7=0 so we can say Q1Q is perpendiclar to l.
is it true? could you pls explain? i'm not sure..
Related Threads on 3d - Vector question
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
31K
30K
  • Last Post
  • Last Post
  • Last Post
