Division or Multiplication First in 48÷2(9+3) Calculation?
  • Thread starter Museigen
In summary, there was a recent discussion on the precedence of division and multiplication in mathematical notation, leading to the conclusion that there is potential for ambiguity. This is particularly relevant in cases of implied or juxtaposition multiplication, where the convention may differ from the traditional left-to-right rule. To avoid confusion, it is recommended to rearrange equations or use additional parentheses when necessary.
Museigen
2 or 288? Does the division come before the multiplication?
Mathematics news on Phys.org
something tells me the answer they want is 2, but the math says its 288.
So is the left to right rule for multiplication and definition a rule? or a convention?
What distinguishes a rule from a convention when there can only be one right way?
What I mean is, does it arise from axioms or is it just accepted?
Do a search there was an existing thread on this just a few days ago. Eventually it was locked because it ended up in a lot of pointless arguments.
The general consensus was that it's somewhat ambiguous and that we should all try to avoid potentially ambiguous notation.
The main thing to come out of the discussion is to be aware that some people will give implied (or juxtaposition) multiplication a higher precedence than a [itex]\div[/itex] (divide) symbol. So be aware of this potential ambiguity.
Actually that's not the only place it occurs. The same thing happens with notation like [itex]\sin 2x[/itex] which is usually meant to be interpreted as [itex]\sin(2x)[/itex] rather than [itex]x \sin(2)[/itex]. But then with numbers and an explicit "times" symbol we would usually interpret [itex]\sin 30 \, \times \, 10[/itex] as [itex]10 \sin 30[/itex] rather than [itex]\sin 300[/itex].
So there's another common example of implied (or juxtaposition) multiplication altering precedence. This is just something that we have to watch out for. Rearrange you equation to make it non ambiguous or use extra parenthesis if there's no other way.
1. What is the correct way to solve 48÷2(9+3)?
The correct way to solve this mathematical expression is by using the order of operations or PEMDAS (Parentheses, Exponents, Multiplication and Division, Addition and Subtraction). This means that you must first solve the parentheses, then the multiplication and division from left to right, and finally the addition and subtraction from left to right.
2. Should I solve the parentheses first or the division first?
When dealing with PEMDAS, you must solve the parentheses first before moving on to the division. This is because parentheses have the highest priority in the order of operations.
3. Why does the answer to 48÷2(9+3) change depending on the order of operations used?
The answer to this mathematical expression will change depending on the order of operations used because the parentheses group the numbers and operations together, affecting the overall result. If the parentheses are solved first, the answer will be different compared to when the division is solved first.
4. Is the answer to 48÷2(9+3) 288 or 2?
The answer to this mathematical expression is 288. This is because the parentheses must be solved first, resulting in 48÷2(12), which then becomes 48÷24. Following PEMDAS, the division is solved next, giving us the final answer of 288.
5. Can I use a calculator to solve 48÷2(9+3)?
Yes, you can use a calculator to solve this mathematical expression. However, it is important to make sure that the calculator follows the order of operations correctly. Some calculators may not follow PEMDAS, resulting in a different answer than expected.
27K
  • General Math
  • General Math
  • General Math
  • General Math
