How does ending in 5 impact the divisibility of x by 7 in Pell's equation?
  • Thread starter mathslover
In summary, we discussed the solutions of Pell's equation x*x-2*y*y=-1 and how to prove that whenever y ends in digit 5, then 7 | x. We explored the general solution for this equation and used induction to prove that if X and Y are a solution pair then (3X+2Y) and (4X+3Y) are the next solution pair. We also discussed how to prove the divisibility by 5 and 7 using modular arithmetic.
mathslover
guys,
From the solutions of the Pell's equation x*x-2*y*y=-1,
how can we prove that whenever y ends in digit 5, then 7 | x ?
-Mathslover
Perhaps I should clarify a bit,x*x-2*y*y=-1 has solution
x=1, 7, 41, 239, 1393, 8119, 47321, 275807,...
y=1, 5, 29, 169, 985, 5741, 33461, 167305,...
and the general solution is (xn+yn*sqrt(2))=(1+sqrt(2))^(2*n+1)
Apart from induction,how can we prove whenever 5|y then 7|x ?
What about y=15?
bel said:
What about y=15?
For y = 15 there are no solutions, since sqrt(449) isn't an integer... right?
The first solution pair (x,y) is (1,1). Develop a recursive relationship for the nth such pair (xn, yn) in terms of previous pair(s). The relation you want to prove will fall right out.
Do you the general solution to this Pellian equation? I think that is the way to approach this problem. Followed by induction.
[tex](1 +\sqrt{2})^n[/tex] gives [tex]X_{n}\sqrt{2} + Y_{n}[/tex] where [tex]X_{n}[/tex] and [tex]Y_{n}[/tex] for odd [tex]n[/tex] are solutions.
thus the first 3 solutions pairs X,Y are
1,1
5,7
29,41
from this one might notice that 5 = 3*1+2*1 and 29 = 3*5+2*7 and also notice that
7 = 4*1 + 3*1 and that 41=4*5+3*7.
Or simply multiply [tex](X\sqrt{2} + Y)*(1+\sqrt{2})^2[/tex] and put back into the same X,Y form to find the new X and Y.
So prove that if X and Y are a solution pair then (3X+2Y) and (4X+3Y) are the next solution pair then consider X mod 5 and Y mod 7 and you can follow the rest by induction.
1,1
5,7
29,41
Since [tex](1+\sqrt{2})^2 = 3+2\sqrt{2}[/tex] and since [tex](1+\sqrt{2})^3 = 7+5\sqrt{2}[/tex] then
[tex]X_{n} = 0 \mod 5[/tex] implies that [tex] n = 0 \mod 3 [/tex]
but [tex]X_{n}[/tex] is only a solution for odd n so we calculate [tex](1 + \sqrt{2})^6 = 99 + 70\sqrt{2}[/tex] so the next solution after n = 3 (x=5, y = 7) is
[tex]X_{n+6} = 70*Y_{n} + 99*X_{n} \| Y_{n+6} = 70*2*X_{n} + 99*Y_{n}[/tex]
From inspection of the above formula it can be seen that
[tex]X_{n} = 0 \mod 5[/tex] if and only if [tex] X_{n+6} = 0 \mod 5[/tex] and
[tex]Y_{n}=0 \mod 7[/tex] if and only if [tex] Y_{n+6} = 0 \mod 7[/tex]
So our proof is complete
What is Pell's equation 5 and 7?
Pell's equation 5 and 7, also known as the Diophantine equation, is a mathematical problem that involves finding integer solutions for the equation x^2 - 5y^2 = 7.
Who discovered Pell's equation 5 and 7?
Pell's equation 5 and 7 was first discovered by the English mathematician John Pell in the 17th century.
What is the importance of Pell's equation 5 and 7 in mathematics?
Pell's equation 5 and 7 is important in mathematics because it is one of the few Diophantine equations that can be solved using algebraic methods. It has also been used in various applications, such as cryptography and number theory.
What are some strategies for solving Pell's equation 5 and 7?
There are several strategies for solving Pell's equation 5 and 7, including using continued fractions, the Chakravala method, and the Bhaskara-Brouncker algorithm. These methods involve manipulating the equation to find integer solutions.
What are some real-life examples of Pell's equation 5 and 7?
Pell's equation 5 and 7 has been used in real-life examples such as finding the shortest distance between two points on a chessboard and calculating the number of solutions to certain polynomial equations. It has also been used in cryptography to create secure encryption algorithms.
  • Linear and Abstract Algebra
  • General Math
