• Support PF! Buy your school textbooks, materials and every day products via PF Here!
∫(6/(x^2 - 4x -12).dx=?
  • Thread starter brandy
1. Homework Statement
3. The Attempt at a Solution
i went
6*∫1/(x^2 - 4x -12)
which i then worked out to be 6*ln(x^2 - 4x -12)/(2x-4) +c
ie 6*ln u / u'
where u=x^2 - 4x -12
im not very good at this. is this correct?
HallsofIvy
41,681
864
No that is not the integral. I imagine you tried making the substitution u= x^2- 4x- 12 so that du= (2x-4). But you cannot just divide by 2x-4 and say that dx= du/(2x-4) because that is a function of x itself- you cannot just move it inside the integral sign as you could a constant. Instead factor x^2- 4x- 12 and use "partial fractions".
161
i dont really know what you are saying. can you dumb it down alot more. im a real dummy :)
my thinking:
6/(x^2 - 4x -12). 6 is a constant so it can be brought to the other side of the integral.
now you have 6*∫1/(x^2 - 4x -12)
i thought that ∫1/(x^2 - 4x -12) is ln (x^2 - 4x -12)/(2x-4)
i take it this is where im wrong?
can you explain better?
Cyosis
1,495
Using your substitution you would get the following integral:
[tex]
6 \int \frac{1}{2x-4} \frac{du}{u}
[/tex]
You then seem to treat the [tex] \frac{1}{2x-4} [/tex] term as a constant and you put it in front of the integral and integrate with respect to u. The mistake you make here is that x itself depends on u, so x is not a constant with respect to u. So before you integrate you have to rewrite the fraction in terms of u. As a result you can't take the fraction out of the integral.
As Ivy suggested you want to factor the denominator and then write the integrand as [tex]\frac{A}{x+a}+\frac{B}{x+b}[/tex]. You should be able to determine the constants A,B,a and b and then solve the integral.
On a different note if you're unsure whether or not you did the integration correctly, it is a good habit to take the derivative of your answer and see if it equals the integrand. If it doesn't you know you have made a mistake.
Related Threads for: ∫(6/(x^2 - 4x -12).dx=?
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
