1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
7 Segment Display / Counter
  1. Jun 13, 2009 #1
    Hi there
    Im building a 7 segment display that counts to 10 when a switch is activated .. this is on Multisim. Ive built it to how i think is correct .. Unfortunatly is doesn't seem to be doin anythin at all ..
    Any help is appreciated
  3. Jun 13, 2009 #2
    Hi Dave and welcome.
    You would need to post a copy of your circuit.
    It is common in logic circuits like counters to have a number of pins that have to be grounded or brought to the 5 volt reference level. Have a look for pins like "reset" and "enable" that have to be treated like this and check which way they need to be connected.
  4. Jun 14, 2009 #3
  5. Jun 14, 2009 #4
    Can't really see the circuit, but if that is a TTL 7490 or similar, you would need to pull the input to ground rather than to 5 volts when you provide a series of pulses to check the counter.
    TTL inputs are already at "high level" and need to be grounded for the counter to change state.
    Can you make the circuit a bit bigger?
  6. Jun 15, 2009 #5
  7. Jun 15, 2009 #6
    You are still pulling the input high with the switch. It is already high so this will not work.
    Put a 1K resistor from input to ground and leave the switch where it is.
    Or put a 1 K resistor to 5 V from the input and a switch to ground. Simulators like you to be definite about your intentions.
    There may be other problems, but the circuit is still unreadable here.
  8. Jun 16, 2009 #7
    Thanks alot ... This seemed to fix the problem
