A ball rolling up a parabolic ramp
errwrsysalan
1. Assume there is gravity and no external force acting on the system. A ball has an initial velocity of 5 m/s and climbs up a parabolic ramp, which is defined by y=(x^2)/3. If the ball rolls exactly along the path of ramp and energy of the ball is conserved, starting from (0,0), calculate the time taken for the ball to climb to a height of y=1.
2. Ek+Ep=Einit, Vy=||v||sin(arctan(dy/dx))
3. I made a differential equations using the formula above but the differential I got is only numerical integratable (results given by wolfram alpha). I'm looking for an easier way to solve this problem. So, guys, please help! Thanks!
Answers and Replies
Simon Bridge
17,874
1,657
What did you need the trig for?
Did you start with ##\frac{1}{2}m(\dot x^2+\dot y^2) + mgy = \frac{1}{2}mu^2 : u=5,\; y=\frac{1}{3}x^2## ?
errwrsysalan
That seems pretty helpful! I haven't learnt to use and x and y things because I'm a highschool student, but I've done stage 1 college maths so I think I can cope with that. I'll give it a try! Thank you!
Simon Bridge
17,874
1,657
Is this a problem set for high school?
errwrsysalan
Well. It's not, I made this question up. It'd be nice if you can solve it using highschool knowledge only though.
errwrsysalan
errwrsysalan
I might got it.. trying now
errwrsysalan
I'm trying now, but still, can you show me how you would do it please?
Guess what. I used the formula you gave me and that ends up the same differential equation I got last time using trig, which I need to use a computer to calculate it. Can you help me?
Simon Bridge
17,874
1,657
Please answer the question?
errwrsysalan
I answered above. Basically this is some extracurricular work.
Simon Bridge
17,874
1,657
Sorry - misread.
errwrsysalan
Sorry - misread.
It's ok. So, right now I used your formula, and it ended up exactly the same as last time I did it using trig.
I got dt/dy=0.5sqrt((3+4y)/(25y-2gy^2)) dy, which even wolfram alpha couldn't give an exact solution.
I believe there is a better way to do this. Can you show me please?
Simon Bridge
17,874
1,657
... this is a specific case of an object sliding inside a parabolic bowl.
If you google for that, you'll get a bunch of examples. i.e. See attachment below.
Note: ##\dot x = v(x)## is where you get stuck.
You can do $$T = \int_0^{\sqrt 3} \frac{dx}{v}$$ ... i.e. what you were doing but as a definite integral.
The indefinite integral involves elliptical functions.
It is not unusual for quite simple-seeming setups to be very difficult to solve - or even have no analytic solutions at all.
ie. Try working out the exact equation of motion for a simple pendulum - or a puck sliding in a spherical bowl.
  • ADA574905.pdf
errwrsysalan
I'd usually reach for lagrangian mechanics.
Try working out the exact equation of motion for a simple pendulum for example - or a puck sliding in a spherical bowl.
Thank you! No problem. I need to sleep as well. I'll have a look tomorrow.
Suggested for: A ball rolling up a parabolic ramp
19K
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
