Questions About Shifting & Ignition Keys
  • Thread starter Pre-AlgebraDude
  • Tags
    Ignition
In summary: Are we talking crazy big old American cars here, with drum brakes, gas lamps, and hand starters?!...Yes, those are the types of cars I'm talking about.
Pre-AlgebraDude
I was wondering, anyone who know about cars and such, is it hard on your transmission to shift it while you're moving? I do it all the time, but my don't-abuse-transmission-crazy dad yells at me and says it is, but I've seen it done before many times, and they keep right on going. And I mean from like reverse to drive, or drive to low gear.
Oh, and is it possible for your car key to be run through the ignition/door locks so many times and it gets worn out to the point where it doesn't work anymore?
How do you mean, to shift it while you're moving? The whole point of a transmission is so you can change gear while you're moving!
You should only shift into reverse while the car is stood still.
You shouldn't shift from a high gear into a very low gear since the road wheels will force the engine speed right up, and possibly over its limit. This is more of an engine concern than a transmission concern though.
Possible, yes. I've never heard of it happening though, even on really old, frequently-used cars.
I mean in automatics! and I mean going to lower gears for better braking. should you stop first?
Your father is right, more so if you drive a ford or chevy. I would yell at my kid too if he did that...but he dosen't :smile:
note...no, you don't stop for lower gears...but into reverse..and out of reverse ..YES
No. That would be silly.
I think brewnog misunderstood your question. You're referring to automatic transmissions, aren't you ? It *is* bad for the transmission to go between L, 2,3, D whilst moving. Keep doing it and you'll fry your tranny in little time.
You should only engage the low gears when you need to climb steep hills. In that case, the car should be brought to a complete standstill and you should gently move the lever to L or 2 or whatever. You should keep it in low gear for the downhill descent as well, it will afford you engine braking and prevent overheating of the brakes. When you've crested the hill, slow down to a near standstill before engaging D, then moving off on a flat road.
Manual gearboxes afford a lot more control (of course). They can even be shifted without using the clutch if you know how to match revs (but this is not advisable, since it never comes out perfect unless you're using a special kind of transmission with straight-cut gears, called a crashbox or dogbox).
first and second gear on an automatic are for "pulling stumps out of the ground".
Even with an automatic, I've never heard that there's anything wrong with changing out of D whilst moving. The only difference is that you're making the decision, instead of the gearbox. Modern automatic systems will even override any gear change you make which would force the engine revs dangerously high.
Are we talking crazy big old American cars here, with drum brakes, gas lamps, and hand starters?! :smile:
I don't believe there is anything wrong with going into L or 2 while moving forward, as long as you are going somewhat slowly. I do it quite frequently when I'm driving on ice in fact (basically 6 months out of the year living in Ohio) shifting on ice is a fairly good way to slow the car down without spinning it out on ice.
~Lyuokdea
I stand corrected. There should be no problem when moving from D to L whilst moving, at least at low speeds. And, as brewnog said, even if you screw up, most modern autos are designed to prevent over-reving the engine. Times when you might want to use the lower gear lock would include hazardous conditions, as Lyuokdea pointed out.
What you shouldn't do is to go from D to N or especially D to R whilst moving. Those are bad, no question about it.
I don't have much experience on autos, having driven only manuals all my life. I'll never drive an auto, though I might consider a proper F1 style paddle shifted SMG. :D
I know about manual transmissions. Yeah, I'm talking about american cars.
by the way, hypatia, what's wrong with ford and chevy?!
WTF are you talking about, hand starters, gas lamps, and drum brakes? You got something against American cars?!
Our cars start with keys, just like any other cars. Oh wait, I forgot, you gotta-be-fancy-know-it-all Britains got to have "push button" starters and "push button" transmissions (no offense; I don't like foreign cars, that's all).
lol, once I had the truck in 4 wheel low, and first gear, and my dad gets in a and goes "why you got it in tree-climbing gear"?
One more thing, I mean shifting it from reverse to drive while it is barely moving, like you're fixing to put it in drive, but you shift it about a second and a half before it gets stopped, and stupid sluggish transmissions don't shift 'till about a second after you've put it in gear, so you're pretty much stopped by the time the transmission catches up with you.
On american cars you'll bust a tooth off the gear doing that.
Well, I used to shift from R to D while still moving backwards. Not a good idea. Of course, now I drive stick, so you can do that without any problem.
The lower gears on an automatic work great when going down a long slope on a mountain or something if you don't want to wear out your brakes. It's called engine compression breaking I believe. In normal driving conditions, don't do it...
Both Ford and Chevy car owners manuals use to tell you never to shift into reverse without being at a compleat stop.
What's wrong with going from D to N? Are you sure you didn't mean D to P? Other than trying to restart the car while still rolling if you stall on a highway, I'm not sure how many other uses there are for Neutral on an automatic (remember, I grew up in NJ, you don't always have the option to brake and pull over before restarting; whether it's good or bad for the engine is irrelevant when the greater threat is the car barrelling toward you from behind).
I meant D to N. There are a lot of drivers who think the "right" thing to do when stopped at a light is to shift the car to N then back to D when moving off. This is wrong.
From the Automobile Association of Singapore website FAQ on auto trannies :
"Q. Does one keep the auto gear engaged while waiting for the traffic light to change to green or shift it to neutral?
A. The gear should remain at D position. Changing gear frequently from D to N and back will cause more wear to the valves and clutch plates.
Q. Is it true that it is not advisable to "free"the gear at N and let the vehicle roll slowly when approaching a traffic light?
A. It is not advisable to shift to N while on the move as this may damage the internal parts of the device. When engaged at N, deceleration will allow the output shaft to overrun the hydraulic clutches and the gear trains of the gearbox. All hydraulic clutches at this gear will be at a disengaged position. The driving and driven plates will be separated slightly as they rub against one another, causing premature wear and tear. At D position, the governor or speeds sensor in the Electronic Control Transmission is still in operation. There will then be an automatic downshift, also known as coast downshift, to give better control of the vehicle and engine braking."
No way. Half of the time driving the Roadrunner or any other 4-gear, I didn't bother with the clutch. The shifts are smoother than with one.
The El Camino has a manual valve body in the 350 Turbo tranny, so I can make positive down-shifts whenever I want to. That's good, because I have to do it to stop. If I use the brakes driving around town, they start squealing within a few blocks. Those 33" tires put a hell of a load on them, even with a light vehicle. Also, my town is located at the bottom of 3 incoming 8% grade hills. First or second gear is the only way to keep from speeding without constantly using the brakes. Trucks are required to use low gears, but using a jake within town limits is illegal. The biggest problem with positive down-shifting is reverse shock loads on the U-joints and engine bearings.
As for the keys, they most definitely will wear out. GM's are the worst because they're so small to start with. If you can pull a GM key out of the ignition without turning it off, it's time to replace it. Since the wafers wear along with the keys, and the keys get thinner as well as stubbier, it's usually a matter of the key breaking before it stops working. Get your duplicates made before the first one wears down, or have it cut to code. A new key cut by tracing from a worn one usually won't work properly.
I drove my Toyota as if it were a stick shift for a while. Mechanics spotted it right away. They said "You're not supposed to drive an automatic like it's a standard." I'd burned out the tranny.
It's not that the actual engine rev causes damage, the tranny of an auto is not meant to withstand the wear & tear like a manual. The friction plates between axle and drive train will burn out.
Your dad's bang on.
Oh, okay, I've never heard of anyone doing anything weird like that. Though, that's not a problem for the transmission, but the clutching mechanism. That would rather defeat the purpose of having an automatic if you had to keep shifting when approaching lights. :rolleyes: (Needless to say, you don't want to be slamming the car into Park without it being at a full stop first either ).
For a standard, it's better to be in Neutral when you're stopped at a stop light. For automatics, you shouldn't interfere with the transmission's operation unless you have a good reason. Going down prolonged steep grades is a good reason to put the car in a lower gear and leave it there (every so ofen, we have a few Pikes Peak tourists that ignore that advice, manage to skip the mandatory brake check at Glenn Cove, and wind up plunging over the side of the mountain to their deaths when their brakes overheat and fail - makes for a chilling tale from witnesses who see the car speeding down the hill, honking it's horn, and flashing it's lights.
Shifting from Reverse to Drive (or vice versa) is bad for both Standards and Automatics. You can probably get away with it at extremely slow speeds, but it's still a bad idea and wears on your transmission. I borrowed a friend's standard that had a small shifting problem. You had to go almost all the way up to Reverse to go from 1st to 2nd or from 2nd to 1st. Going up a hill, I went up just a little too far while going from 2nd to 1st, mistimed the clutch, and dropped his bell housing all over the road, even with the clutch barely disengaged. Fortunately, it had enough other problems that he wasn't too broken up about it.
The 4WD is a completely different matter. You can shift into 4-Wheel high while moving, but I wouldn't do it at extreme speeds (75 is the speed limit on the expressway and that's probably pushing it as an upper limit for shifting into 4WD). To shift into 4-Wheel low, you should be stopped or barely moving - of course, you should be going pretty slow if the conditions require 4-Wheel low, anyway. I don't think you're supposed to drive above 20-25 mph while in 4-Wheel low.
It is not fatal, but it does make the engine work harder. When I lived in Germany, down south in Bavaria and Austria there are signs in the mountainous areas suggesting to use your engine to help braking on the downward slopes. Your brakes will overheat before your engine does (if it is maintained properly).
Like Brewnog said before, you do have to make sure that your RPMs don't redline when you downshift.
I have driven both, and I agree with Curious - shifting an automatic transimission (which I do on occasion) like a manual one is going to increase where and tear, simply because one will increase the load/stress on the components. Use the brakes - brake pads are relatively cheap compared to transmissions.
As for going downhill, use low gears, but one does not have to stop first. One should rev the engine though to get the engine speed compatible with the lower gear. Use the breaks to keep the speed down and minimize stress on the engine/transmission.
. Despite what they might say, Quality is not Job #1. :rolleyes: Chevy is the lowest (cheapest) end of the GM line. Ford is about the same. Highest quality goes into Cadillac (GM) and Lincoln/Mercury (Ford), but even there, one has to watch it.
Ha, we used to have an old 4WD. When shifting from 2WD to 4WD high (or low, for that matter), you had to stop, and you usually had to reverse a few metres for the front hubs to engage properly! That was fun...
lol, you guys don't still use metal keys do you?
kind of hijacking here but since this is a car/transmission thread,
in a standard, is it better to gear down while coming to a stop? this would obviously save a bit of wear on the brakes because the engine is doing some of the breaking, but does doing this not also increase the wear on the engine? plus wouldn't the high revs increase the gas consumption? So what is better, shifting through the gears while stopping, or just putting it in neutral/holding the clutch in ?
thanks
These days, it's best practice not to use engine braking routinely. Brake pads cost a few quid, which is a lot less than the cost of the extra wear you're putting on your running gear. Just stick in a sensible gear, use the brakes to brake.
On a modern car, no. Your ECU shuts off the fuel to the engine on the overrun, for that exact purpose.
Either shift down when the car has already slowed down by the brakes, or just come to a standstill in whatever gear you were in, then stick it in first/neutral. Do NOT just hold the clutch in, - this results in a lack of control. It also wastes petrol!
Obviously on a long or steep downhill, you should use a lower gear anyway, but this is to reduce the risk of brake fade rather than to minimise wear on the brakes.
Use your brakes kids, it's what they're for.
Why? Oh yeah, you fancy Brits got to use "push button". Seems to me like you're just to lazy to turn a freakin' key. The new corvette has a push button as an option, but other than that, never seen an American without a key. I'd rather have a key, because that little button could go out. Like Toyota's new Avalon, and what Mercedes is doing with this "remote" crap, where that computer has to recognize the remote inside before it let's off the engine lock, or some crap like that, and if that computer fries, your car is useless. Just give me a key for that matter. Too complicated for a simple southerner like myself.
Danger, I know what you mean, my dad had an old seventy-something Caprice and the key was crap. I still happen to have a door key, and it's chipped and you can tell that the chip is old. So small, I can actually bend it.
brewnog:eek:ur truck will not go into 4WD in reverse. It just chugs and jerks, and won't go into gear.
I discovered today that it's bad to go to neutral (even when going very slow, like turning around in the driveway), because the car just binded up (didn't stop, just got REALLY sluggish). That can't be good.
i actually work for mercedes and its surprising how reliable the keyless-go system works. But although every mercedes comes with an ignition they don't use a metal key but rather an infra red recognition system thingy, at least i think it does, all i normally do is change the oil.
1. What is the purpose of shifting and ignition keys?
The shifting and ignition keys are used to start a car's engine and shift the gears, allowing the car to move forward or backward.
2. Can I use any key to start my car?
No, each car has a unique key that is specifically designed to fit into the ignition and start the engine. Using the wrong key can damage the ignition system and prevent the car from starting.
3. How do I know if my shifting and ignition keys need to be replaced?
If your keys are worn, bent, or damaged, it may be time to replace them. You may also notice difficulty in turning the key or starting the car, which can indicate a problem with the keys.
4. Can I get a spare key made for my car?
Yes, it is always a good idea to have a spare key in case you lose or damage your original keys. You can get a spare key made at a dealership or a locksmith.
5. Why do some cars have push-button start instead of traditional ignition keys?
Push-button start is a newer technology that eliminates the need for a physical key. Instead, a key fob is used to send a signal to the car's computer, allowing it to start the engine. This technology is becoming more popular because it is convenient and reduces the risk of car theft.
  • General Discussion
  • Mechanical Engineering
  • Electrical Engineering
  • STEM Career Guidance
