Elastic Collision of Point Mass and Dumbell: Analyzing Kinetic Energy
In summary, the scenario described involves a point mass M traveling at velocity V colliding with a dumbell composed of two masses of M/2 separated by a massless rod of length L. The collision is elastic, and after the collision, the original mass is stationary while the dumbell moves at velocity V to the right. However, the dumbell also starts spinning and has additional kinetic energy, causing confusion in the analysis. It is important to consider the conservation of momentum, angular momentum, and energy in solving this problem, as the result of the collision depends on where the incoming mass strikes the dumbell. If it hits the middle, the incoming mass will come to rest, while hitting one of the balls of the dumbell will result
daveed
138
Say we have a point mass [tex]M[/tex] traveling to the right at velocity [tex]V[/tex]. It strikes a dumbell composed of two masses of [tex]M/2[/tex] separated by a massless rod of length [tex]L[/tex]. The collision is elastic.
I am having some trouble thinking about this...
After the collision, the original mass is stationary because the dumbell has the same mass, so that ends up going at [tex]V[/tex] towards the right.
However, it also starts spinning, and has a certain kinetic energy. But if the dumbell is moving to the right at [tex]V[/tex], it would have the same translational kinetic energy as the original mass. So the rotational kinetic energy would be extra, and therefor something has gone horribly wrong in my analysis.
Is my assumption that the original mass stop moving incorrect? This holds true for regular, point masses colliding(ie. billiards balls), but I guess it wouldn't be for systems with rotational parts. Because to have an elastic collision means only to have kinetic energy conserved, I suppose that the original mass retains some of its momentum to the right, and gives the dumbell some, and I have to solve for the velocities/angular velocities such that the total energy in the system is conserved. Is this the right analysis of the system?
Use lower case "t" in tex.
The result of the collision depends on where the incoming mass strikes the dumbell. If it were to hit the dumbell exactly in the middle then the incoming mass would come to rest just like in the point particle case. If it hits one of the balls of the dumbell then it won't come to rest. Solve the problem by applying conservation of momentum, angular momentum, and energy.
1. What is an elastic collision?
An elastic collision is a type of collision where the total kinetic energy of the system is conserved. This means that the total energy before the collision is equal to the total energy after the collision.
2. How is kinetic energy calculated in an elastic collision?
Kinetic energy is calculated by using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity. In an elastic collision, the kinetic energy of the system is the sum of the kinetic energy of all the objects involved.
3. What is the difference between a point mass and a dumbbell in an elastic collision?
A point mass is a theoretical object with no size or shape, whereas a dumbbell is a physical object with a specific size and shape. In an elastic collision between a point mass and a dumbbell, the point mass is assumed to be a single point with all its mass concentrated at that point, while the dumbbell is considered as two separate point masses connected by a rigid rod.
4. How is momentum conserved in an elastic collision?
In an elastic collision, the total momentum before the collision is equal to the total momentum after the collision. This is known as the law of conservation of momentum. This means that the sum of the momentum of all the objects involved in the collision remains constant.
5. What factors can affect the kinetic energy in an elastic collision?
The kinetic energy in an elastic collision can be affected by the mass and velocity of the objects involved. A larger mass or a higher velocity will result in a higher kinetic energy. Additionally, the angle and direction of the collision can also affect the kinetic energy.
