A curious paradox
MathematicalPhysicist
369
in this webpage there is a book about recreational maths in it there is a paradox by raymond smullyan, it's on page 189:
http://www.g4g4.com/paul/BOOK.pdf [Broken]
what do you think can the paradox be solved?
Answers and Replies
Hurkyl
Staff Emeritus
Actually, propositions 1 and 2 can both be true.
Recall that if P is false, then P => Q is a true statement.
It turns out that both of these propositions are vacuously true; e.g. if you rewrite the first one in a less misleading fashion, it becomes:
If x > y and y > x, then x - y > y - x.
And the second one becomes
If x > y and y > x, then x - y = y - x
Obviously, the hypothesis of both of these statements is always false, so these statements are always true.
When you combine these statements to produce the "contradiction", you get:
If x > y and y > x, then x - y > y - x and x - y = y - x
Or
If false, then false.
Which is a true statement!
Mathematics is saved; there is no choice of x and y that satisfies the hypothesis of this statement, so the conclusion of the statement never matters!
369
Or
i think it should be if x>y or y>x because you don't know which is greater than the other then you should choose the "or" option.
Hurkyl
Staff Emeritus
"The excess of x over y, if x is greater than y" only gives numbers for x > y.
Similarly, "The excess of y over x if y is greater than x" only gives numbers for y > x.
The only way both of these statements can give a number (and thus for one to make equations and inequations from those numbers) is if both of the hypotheses are true; that is if both x > y and y > x.
369
ok i think i understand your answer.
so there is no paradox.
369
here's another question from the book:
find the smallest prime number that contains each digit from 1 to 9 at least once.
a method i thought about is if 2^n-1 is a prime then n is also a prime but I am not sure this method to tackle the question (ofcourse other than checking evey number from the smallest number (which i haven't checked if it's a prime) 123456789 and then checking if it's not divisible by the numbers smaller than it.
Hurkyl
Staff Emeritus
First off, 9 will divide any 9-digit number that contains each of 1, 2, 3, ..., 9... so you have to have at least one repeat.
If I were to tackle this problem, I would simply examine the smallest 100 or so 10-digit integers that contain each digit. If none of them are prime, then I would go back to the drawing board and try to figure something out.
369
i didnt know that.
is there a reason for that?
369
could it be said that a number who is divided by 9 could be divided by 3 (i think so because 9 is a multiple of 3).
Hurkyl
Staff Emeritus
The classic test for divisibility by 9 is:
x is divisible by 9 iff the sum of the (base 10) digits of x is divisible by 9.
For a quick proof, notice that
Σi di 10i = Σi di 1i (mod 9)
1 + 2 + 3 + 4 + 5 + 6 + 7 + 8 + 9 = 45, and 45 is divisible by 9, so any number which has exactly one of each of these digits must be divisible by 9.
And yes, anything divisible by 9 is divisible by 3.
uart
Or
Hey, it's even simpler than that. All the first proposition is really saying is that if one of the numbers (x or y) is equal to twice the other number then the difference is equal to one times the minimum (of x and y) but equal to one half times the maximum. Of course there is no paradox when stated like this and it is perfectly compatible with proposition 2.
The apparent paradox comes from the authors use of the variable y as both the smallest number, min(x,y), in the first instance and also as the largest number, max(x,y) in the second instance. So y is not a constant unless a different set of two numbers is used for each case, which would make the comparision pointless anyway.
Hurkyl
Staff Emeritus
Well, the reason I explained it this way is because phrasing can sometimes be very important, so I didn't want to "cheat" by rewriting their claim.
Suggested for: A curious paradox
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
