Homework Help: A differential Problem
  1. Oct 18, 2015 #1
    Chemical reactions being studied in which a body A undergoes transformations
    according to the following scheme:
    http://prntscr.com/8shuvb
    k1, k2, k3 , k4 are the rate constants .
    We denote x (t ), y ( t) , z (t) the respective concentrations of the products A, B, C at a given time t
    ( t expressed in minutes).
    The initial conditions x (0) = 1, y (0) = 0 and z ( 0) = 0 .
    Is arranged above the vessel where the reaction takes place by a burette which is poured
    product A at a constant speed in the tank. Under these experimental conditions,
    functions x , y, z defined on the interval [0 ; + infinite [ check the following differential system :
    dx/dt (1-2x +y+ z)
    dy/dt (x - y)
    dz/dt (x - z)
    Question 1:
    Calculate d/dt( x + y + z) and , using the initial conditions, deduce that :
    y(t) + z(t) = 1 + t - x(t)
    Question 2:
    Demonstrate that x is a solution of the differential equation (E) : dx/dt + 3x = 2 + t, then resolve
    Equation ( E) knowing that it validates the initial condition x (0) = 1 .
    2. Relevant equations
    3. The attempt at a solution
    Question 1:
    dx/dt+dy/dt+dz/dt= 1-2x+y+z+x-y+x-z
    integral dx/dt+ integral dy/dt+ integral dz/dt= integral ( 1 dt)
    x(t)+y(t)+z(t)=t*c
    y(t)+z(t)=t*c-x(t)
    Question 2:
    dx/dt+3x=2+t
    dx/dt =2+t-3x
    dx/dt(x) =1
    1= 2+x-3x
    1=2+-2x
    ... does not work. :(
    I am not sure what to do here, some tips would help.
  3. Oct 18, 2015 #2
    ehild
    You need an additive constant when integrating, not a multiplicative one!
  4. Oct 18, 2015 #3
    epenguin
    Rather a weird question so I wonder if you have reproduced it properly.
    First substances are called A, B, C then the same substances are called x , y, z.
    Then four rate constants k1, 2, 3, 4, are mentioned, afterwards they have all become 1.
    The rate of addition is also 1.
    OK if the model has been so simplified, you can simplify it a bit further yourself: since y and z are formed and decompose at exactly the same rate and are initially at the same concentration, y = z at all times it is sufficient to formulate e.g.
    Constant supply rate 1 ⇒ x ⇔ w
    where the forwards and backward rate constants are both 2; at the end of the calculation get y and z back from y = z = w/2.
    ____________________
    (Corrected)
  5. Oct 18, 2015 #4
    oops, made a mistake, but is that a good answer ?
    y(t)+z(t)=t+c-x(t)
    and for question 2 how do I do it?
  6. Oct 18, 2015 #5
    ehild
    It is correct. Find the value of c from the initial conditions.
    Substitute y(t)+z(t) back into the first equation, you get the desired differential equation for x(t).
    It is a first-order linear equation, solve with one of the standard methods you certainly have learnt.
  7. Oct 18, 2015 #6
    this is the first equation ?
    dx/dt + 3x = 2 + t
    how am I supposed to substitute ?
  8. Oct 18, 2015 #7
    ehild
    I meant y(t)+z(t) substituted into dx/dt = (1-2x +y+ z).
    You should get the equation dx/dt + 3x = 2 + t, but you have to prove it.
    The next task is to solve this differential equation and give x(t) using the initial condition x(0)=1.
  9. Oct 18, 2015 #8
    dx/dt=1-2x+(y+z)
    dx/dt=1-2x+(1+t-x(t))
    dx/dt=2-2x+t-x(t)
    dx/dt=2-3x+t
    dx/dt+3x=2+t
    by doing this I prove that X is a solution ?
    and now I just resolve this as a normal linear differential equation ?
  10. Oct 18, 2015 #9
    ehild
    You derived the de for x(t). Resolve it as a normal linear first order differential equation.
  11. Oct 18, 2015 #10
    Mark44
    Staff: Mentor
    A differential system is a system of equations, each of which should have = in it somewhere.
    Is this the system?
    dx/dt = 1 - 2x + y + z
    dy/dt = x - y
    dz/dt = x - z
    This doesn't make any sense to me. You need to have x as some function of t. The differential equation you show above (equation E) is a first-order, nonhomogeneous equation. One technique for solution is to find an integrating factor.
  12. Oct 18, 2015 #11
    okay, 1 and 2 is done thank you very much. This problem confusing me a lot.
    Now for Question 3:
    Prove that d/dt(y - z) + y - z = 0 and deduce that y = z
    d/dt(y - z) = 0 so,.
    y-z=0
    y = z
    Not sure if I am doing this right.
  13. Oct 18, 2015 #12
    ehild
    How did you get the equation in red?
    Start with the original equations in the problem.
    dy/dt (x - y)
    dz/dt (x - z)
    Subtract them. What do you get?
  14. Oct 18, 2015 #13
    (x-y)-(x-z)= -y+z
    d/dt(y - z) + (y - z) = 0
    d/dt(-y+z) + (-y+z) =0
  15. Oct 18, 2015 #14
    ehild
    Sorry, the original equation missed the equal signs.
    So it should have been
    dy/dt= (x - y)
    dz/dt =(x - z)
    When you subtract them, it becomes d/dt(y-z)+(y-z)=0
    You can consider y-z as a new function v = y-z, and you have the differential equation dv/dt+v=0. What is the solution for v(t) and what is the initial condition?
  16. Oct 18, 2015 #15
    I dont understand how it becomes d/dt(y-z)+(y-z)=0
    when I subtract them I get (x - y)-(x - z) = z-y
  17. Oct 18, 2015 #16
    ehild
    Subtract both sides. On the left sides, you have the derivatives of y and z : dy/dt and dz/dt. What is their difference?
  18. Oct 18, 2015 #17
    ah Okay,
    so its like this: dy/dt - dz/dt = x-y-(x-z)
    dy/dt - dz/dt =-y+z
    dy/dt - dz/dt +y-z =0
    d/dt(y-z) + ( y-z) =0
    dv/dt +v =0
    I find v(t)= C * e-t
  19. Oct 18, 2015 #18
    ehild
    Good. What were the initial conditions for y and z?
  20. Oct 18, 2015 #19
  21. Oct 18, 2015 #20
    ehild
    What initial condition does it mean for v?
  22. Oct 18, 2015 #21
    v(t)=y(t)-z(t)
    v(0)=0
  23. Oct 18, 2015 #22
    ehild
    So what is v(t)?
  24. Oct 18, 2015 #23
    v(t)= 0
    y(t)-z(t)=0
    y(t)=z(t)
    You are awesome, thank you so much for the help.
    Last thing, I want to push this problem a little bit.
    now since we know that y(t) is equal to z(t), if I want to find the equation for them.
    y(t)= 1 + t - x(t) - z(t)
    z(t)= 1 + t - x(t) - y(t)
    is this how I do it?
  25. Oct 18, 2015 #24
    ehild
    Not quite.
    You know that y(t)=z(t), and y(t)+z(t)=2y(t) =1+t-x(t). You also know x(t). What is y(t) then?
  26. Oct 18, 2015 #25
    x(t)= 1/9 *(4/e3t+3t+5)
    2y(t) = 1+t- x(t)
    2y(t) = 1+t-1/9 *(4/e3t+3t+5)
    y(t) = (1+t-1/9 *(4/e3t+3t+5))/2
    and
    z(t) = (1+t-1/9 *(4/e3t+3t+5))/2
    both same equation.
Have something to add?
Draft saved Draft deleted
