A doubt on fluid mechanics
  • Thread starter iitjee10
Q2. An incompressible fluid with density ρ is in a horizontal test tube of inner cross-sectional area A. The test tube spins in a horizontal circle in an ultracentrifuge at an angular speed ω. Gravitational forces are negligible. Consider a volume element of the fluid of area A and thickness dr' at a distance r' from the rotation axis. The pressure on its inner surface is p and outer surface is p+dp.
(a) Show that dp=ρω2r'dr'.
(b) If the surface of the fluid is at a radius ro where the pressure is po, show that the pressure p at a distance r≥ro is p=po+ρω2(r2-ro2)/2.
(c) An object of volume V and density ρob has its centre of mass at a distance Rcmob from the axis. Show that the net horizontal force on the object is ρVω2Rcm, where Rcm is the distance from the axis to the center of mass of the displaced fluid.
(d) Explain why the object will move inward if ρRcmobRcmob and outward if ρRcmobRcmob.
(e) For small objects of uniform density, Rcm = Rcmob. What happens to a mixture of small objects of this kind with different densities in an unltracentrifuge?
This was a problem given in Sears and Zemansky (University Physics)
I have solved parts (a) and (b) of this problem completely. But I could not understand (rather visualise) what Rcm, and Rcmob stand for so was unable to proceed further.
Any help in visualising these terms would be of a great help
Answers and Replies
tiny-tim
25,832
251
Hi iitjee10! :smile:
It's not clear, but I think ρob is not constant (but ρ, the density of the fluid, is) …
so ρob = massob/V.
So the c.o.m. of the object is not at the centroid (where the c.o.m. of the displaced fluid would have been). :smile:
The density of the object has to be constant otherwise the problem here will become hopelessly complicated. This is what I think.
Anyone?
Doc Al
Mentor
44,985
1,249
As explained in the problem statement, one is the distance to the center of mass of the displaced fluid while the other is the distance to the center of mass of the object. They are being very precise and picky!
Not really. For example, part C really has nothing to do with the density of the object, just the force on it from the surrounding fluid.
Related Threads on A doubt on fluid mechanics
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
