Unraveling the Mysteries of DNA Extraction and Precipitation: A Practical Guide
  • Thread starter brovash
  • Tags
    Dna
In summary: DNA has a deoxy portion on the ribose, and is double stranded instead of single, but is this what allows it to be soluble and separable in certain solvents that RNA cant? and if so how exactly?It seems that the main difference between them is that RNA can't be easily extracted using certain solvents, but DNA can. Another difference is that DNA is more soluble in alkaline solutions. What base does to DNA and how it affects its viscosity if at all...does it base hydrolyze it or?I'm not sure, but it might. What acid does to DNA and how it affects its viscosity if at all...again same as
brovash
I am trying to complete an assignment about DNA, and the following questions are nowhere to be found in my textbook/notes nor in any easy-to-understand journals! so any help would be greatly appreciated :smile:
- The difference between DNA and RNA that allows them to be separated...
I know that DNA has a deoxy portion on the ribose, and is double stranded instead of single, but is this what allows it to be soluble and separable in certain solvents that RNA cant? and if so how exactly?
- what base does to DNA and how it affects its viscosity if at all...does it base hydrolyze it or? this one's really confusing me
- what acid does to DNA and how it affects its viscosity if at all...again same as above...really confused
- DNAse affect on visocity of DNA ... this one I know that DNase cleaves and cuts the DNA into parts, and that it reduces its viscosity...but how? it is simply because the molecule is in many smaller parts so it can flow faster or something like that?
- how is DNA precipitated...is it like denatured with certain substances? or is there some sort of charge issue?
Of course I don't expect input on all of these, but any would be really helpful. Thanks!
Some of these questions are pretty interesting and I don't know either! I've found some leads on the difference between DNA and RNA. It has something to do with their relationship with Phenols and Phenols pH on extraction process.
The rest are deep, sorry I can't help :(
I also do not know many of the answers and am interested in what you find. Make sure to post your answers once you get them. It would make for a very interesting read.
A cop out answer is that you may not necesarrily have to chemically separate them using selective solvation (called elution). Remember that RNA molecules are generally composed of many fewer nucleotides than DNA molecules. This could be exploited by running the DNA/RNA mixture in an electrified agarose gel. The RNA will migrate much further toward the positive end.
This method is often sufficient if you are trying to isolate some DNA.
Indeed, if you look at some of the commercially available kits for separating DNA, RNA and protein, and look at the methods used, you might get some hints.
I'll start with your question about precipitation of DNA since that is on the one hand one of what Watson in 'The Double Helix' called 'the witchcraft-like techniques of the biochemist', on the other hand it is one of the nicest things to do in the lab. It precipitates in cold ethanol with an addition of also a % of isopropanol (don't ask!) but what you do is you mix the DNA (dissolved in water/buffer) and the alcohol while stirring with a glass rod. At a certain point you find clear or slightly whitish stuff is adhering to the rod it gets larger and eventually this viscous glassy stuff wrapped around the rod can just be lifted out of the solution, drained and redissoved or dried. A very nice thing to do!
Before that, to get more or less DNA and not much else there. You have to extract from some biological source, remove lipids which you do by extraction with phenol and/or chloroform, proteins whch you do with proteinases, which may also be used to disrupt the cells you are extracting from, and shaking with the phenol/choroform also denatures proteins which gather in the aqueous/organic interface so that gunge can be removed, at some point there is a high salt concentration which causes dissociation of proteins from the nucleic acids they are bound to. RNA is removed by ribonucleases. Here a trick is that there are RNAases that do not need metals, whereas most DNAases - present in the cells and that would start working as soon as you disrupted them - need metals like Zn2+ or Mg2+ which are inhibited by putting in a chelating agent.
Yeah, the viscosity of DNA is due to it being long sticky molecules, as it is cut to shorter its viscosity decreases.
RNA is much more sensitive to alkaline hydrolysis than DNA, because the 2'-OH participates in the hydrolysis with an intermediate 2'-3' cyclic phosphate diester.
You are right that the theoretical textbooks and Scientific American type journals do not tell you much about these aspects and you find them in practical manuals. DNA has to be extracted from different types of tissue for different purposes, so methods vary. A classic recipe was in Marmur, Jnl. of Molecular Biol. 3 208
Hope that helps but you need to see practically oriented books and I hope you can do that extraction/purification yourself once.
What is DNA?
DNA (Deoxyribonucleic Acid) is a molecule that contains the genetic instructions for the development and function of all living organisms. It is often referred to as the "building blocks of life" as it carries the instructions for an organism's growth, reproduction, and function.
How is DNA structured?
DNA is a double helix structure made up of two long strands of nucleotides. Each nucleotide consists of a sugar molecule, a phosphate group, and one of four nitrogenous bases: adenine (A), guanine (G), cytosine (C), and thymine (T). The two strands are held together by hydrogen bonds between these base pairs.
What is the function of DNA?
The primary function of DNA is to store and transmit genetic information. It carries the instructions for the development and function of all living organisms, including the production of proteins that are essential for various biological processes.
How is DNA inherited?
DNA is inherited from biological parents, with half of the genetic information coming from the mother and the other half from the father. During sexual reproduction, the DNA from each parent is combined to create a unique genetic code for the offspring.
How is DNA used in scientific research?
DNA is used in various scientific research fields, such as genetics, molecular biology, and forensics. Scientists can study DNA to understand genetic diseases, track evolutionary relationships, and identify individuals through DNA profiling. It can also be manipulated and replicated in laboratories for various applications, such as gene therapy and genetic engineering.
  • Biology and Medical
  • Materials and Chemical Engineering
  • Cosmology
  • Other Physics Topics
  • Electrical Engineering
19K
