A FORMAL Definition of Large-Scale Isotropy
  1. Aug 23, 2014 #1
    andrewkirk
    Definition of Large-Scale Isotropy and Homogeneity
    This post is part of my attempt to develop a formal definition of 'large-scale isotropy', a concept that is fundamental to most cosmology, but that is nowhere that I have seen properly defined. The definitions of isotropy are as precise as one could wish, but the 'large-scale' bit is in every case I have seen just a hand-wave. It turns out that it's quite messy to try to make that 'large-scale' notion precise.
    I made a thread on it, which is here.
    It is possible that everything below is in that thread, in more up to date and better versions. But I am not sure, and as I don'tr have time to check before the blogs are deleted, I'm posting the material below just in case.
    If you're interested in this topic, I'd suggest going to the linked thread first, and then only coming back to this post if there are links in the thread to it.
    First define ##\Sigma_t## as the hypersurface of constant time t in the foliation.
    ##d(t,P,Q)## is the length of the shortest path in ##\Sigma_t## from point ##P## to point ##Q##, both of which are in ##\Sigma_t##. The length of path is of course determined by integration using the metric tensor.
    ##S(t,P,r)## is the 'spherical' set of all points ##Q\in H_t## such that ##d(t,P,Q)<r##.
    Let ##L(t,P,r)=\frac{\int_{S(t,P,r)}T^{00}dV}{ \int_{S(t,P,r)}dV}## where ##dV## is the volume element in ##\Sigma_t##.
    ##L(t,P,r)## is the average mass-energy density in the 'sphere' ##S(t,P,r)##. As discussed above (in the first part of post #11), this is well-defined because ##T^{00}## is fully determined by the foliation, and invariant to the choice of spatial coordinate system.
    After thinking about it a bit, I feel it may be that a spacetime whose CTHs are perfectly homogeneous must also be perfectly isotropic. If anybody can think of a counter-example, I would be very interested to hear of it.
    However, that is not the case for large-scale homogeneity and large-scale isotropy.
    We can use a variant of the AltH manifold defined in the previous post, to demonstrate a spacetime that is large-scale homogeneous but not large-scale isotropic. Let's call it AltI. It's like AltH except that all slabs have the same width ##a(t)##. That is:
    ##T^{00}(t,x,y,z) = \rho## if ##int(\frac{x}{a(t)})\ ##mod##\ 2 = 0##, otherwise ##0##.​
    Consider the point ##P=(t,\frac{3a(t)}{2},0,0)\in \Sigma_t##. This is in the middle of an 'empty slab'. A straight line through ##P## parallel to the ##y## axis will have ##T^{00}=0## (zero mass-energy density) all the way along its infinite length, because it remains in the same empty slab all the way. However, a straight line through ##P## parallel to the ##x## axis will have ##average(T^{00})=\frac{\rho}{2}##, because it passes through an infinite number of empty and non-empty slabs. So ##\Sigma_t## is not isotropic at any scale because the average densities along the directions of the ##x## and ##y## axes are different at ##P##, no matter how far we pursue those directions.
    But the CTHs of AltI meet the definition of large-scale homogeneity because all slabs are the same width, so the average density in a large enough sphere will approach ##\frac{\rho}{2}##. So AltI is large-scale homogeneous but we would not wish to say it is large-scale isotropic.
    Here is a definition of large-scale isotropy that will exclude AltI, and any other spacetime I can think of that we would wish to exclude.
    Let ##\gamma_{\vec{v}}:[0,\infty)\rightarrow \Sigma_t## be the unique spatial geodesic (meaning a geodesic of the sub-manifold ##\Sigma_t##, not a geodesic of ##M##) through ##P## with initial velocity ##\vec{v}## at ##P##.
    Define ##\mu:[0,\infty) \rightarrow R## by ##\mu(s) = \sqrt{g_{ij}(\dot{\gamma}_\vec{v})^i(\dot{\gamma}_\vec{v})^j}|_{\gamma_\vec{v}(s)}##
    then define ##K(t,P,\vec{v},r)=\frac{\int_0^r T^{00}(\gamma(s))\mu(s)ds}{\int_0^r\mu(s)ds}##. This is the average density along the spatial geodesic from ##P## to ##\gamma(r)##.
    Then we say that ##\Sigma_t## is “large-scale isotropic” iff ##\exists \rho\geq 0## such that, for every ##\epsilon>0## there exists ##R_\epsilon>0## such that, for every ##P\in \Sigma_t## and every ##\vec{v}\in T_PM## orthogonal to ##\vec{\xi}## (recall that ##\vec{\xi}## is the time-like vector field that determines the foliation), ##r\geq R_\epsilon\Rightarrow |K(t,P,\vec{v},r)-\rho|<\epsilon##.
    That is, for any point ##P## in ##\Sigma_t##, the average density along a geodesic curve of ##\Sigma_t## in any direction away from ##P## approaches a limit of ##\rho## as the curve length increases, and a uniform lower bound on the rate of convergence can be achieved for all points in ##\Sigma_t##.
    Then we say that ##\Sigma_t## is “large-scale homogeneous and isotropic” iff ##\exists \rho\geq 0## such that, for every ##\epsilon>0## there exists ##R_\epsilon>0## such that, for every ##P\in \Sigma_t, r\geq R_\epsilon## and every ##\vec{v}\in T_PM## orthogonal to ##\vec{\xi}## (recall that ##\vec{\xi}## is the time-like vector field that determines the foliation), we have ##|L(t,P,r)-\rho| <\epsilon## and ##|K(t,P,\vec{v},r)-\rho|<\epsilon##.
    V.457.
Draft saved Draft deleted
