LaTeX A fractional latex code
  1. Apr 26, 2017 #1
    How can this code be coded by another way?
    ## \frac {300-270.1}{T-130}## = ## \frac {313.-270.1}{135-130}##
    And it is also very strange that the right side O.K but left side is not but everything is the same for left and right.
    #,# \frac {300-270.1}{T-130}## = ## \frac {313.-270.1}[135-130}#,#
    Thank you.
  3. Apr 26, 2017 #2
    jedishrfu
    Staff: Mentor
    I don't see a problem. On the right, you have 313. and on the left you have 300 no dot.
    The denominator is centered under the numerator too. It looks pretty good.
  4. Apr 29, 2017 #3
    But even though code is written with ## it doesn't seem to be in bold type. What is the problem, it shoud have been in bold type.
    Thank you.
  5. May 8, 2017 #4
    I would like to ask about this code:
    Above code is from here: https://www.physicsforums.com/help/latexhelp/
    I am confused because \frac 1 2 should be seem as ## \frac 1 2##. Why it does not work in the rendered code?
    Thank you.
  6. May 8, 2017 #5
    fresh_42
    2017 Award
    Staff: Mentor
    Not quite sure what you mean. If you write \text{ then anything in those brackets is plain text, whether it is a formula \frac{1}{2} or not }.
    Outside this \text{ } command, you get ##\frac 1 2 = \frac{1}{2}## if in formula mode. You even get it inside, as # # ... # # interrupts the \text{ } environment.
  7. May 8, 2017 #6
    This was what exactly I ask. But what does "plain roman text" mean? Would you explain this concept in a most simple way?
    Thank you.
  8. May 8, 2017 #7
    fresh_42
    2017 Award
    Staff: Mentor
    It just means text. You can have a # # ... # # environment with a \text{} or \textrm{} command in between. E.g. if one writes a long formula, or a formula embedded in $ $ ... $ $, then it is often convenient to insert short text entries like "and" or "such that" without having to leave the math mode, e.g.
    \forall x \in X \text{ and } \forall y \in X \; \exists z \in X \textrm{ such that } x + y = z
    which is written as
Have something to add?
Draft saved Draft deleted
