A gas stream (1) contains 18 mol% hexane and remainder nitrogen flows
In summary: The mass flow rate of hexane in stream 1 is 18 mol% and the mass flow rate of nitrogen in stream 3 is 12 mol%.
TonkaTon
Summary: Hello, I need some help with this problem since my professor is bad at explaining (he reads a book and repeats everything), there's a problem online similar, but values and what is asked is different.
A gas stream (1) contains 18 mol% (40.2 mass%) hexane and remainder nitrogen flows to a condenser, where its temperature is reduced so that some of the hexane is liquified. The liquid hexane (stream 2) leaves the condenser at a rate of 990g/min (59.4 kg/h). The uncondensed gas stream (3) leaving the condenser now contains 12 mass% hexane. The process operates at a steady rate.
1. What is the flow rate of the stream (3) in kg/h?
2. What is the flow rate of the stream (1) in kmol/h?
I'd really appreciate if you could help me understand this problem, thank you in advance![Moderator's note: Moved from a technical forum and thus no template.]
I attack these types of problems by starting with a simple flow diagram, on which I write down all relevant information. Then add to the diagram anything that gets you closer to a solution. For example, this problem uses multiple different units (mass%, mol%, g/min, kg/h). Use the information given to calculate the flows in other units, and add that information to the diagram. You will iterate toward the solution.
Most textbooks give the impression that you should just pull the correct formula from the chapter, plug in the numbers, and get the answer. That method works if you can memorize the entire book. Also, if you are doing graded homework or an exam, the diagram shows that you at least understand the problem and how to start solving it. That's usually worth partial credit if you are unable to finish it in time.
Let W represent the mass flow rate of stream 1. In terms of W, what is the mass flow rate of hexane and what is the mass flow rate of nitrogen in stream 1? In terms of W, what is the mass flow rate of nitrogen in stream 3?
1. What is the composition of the gas stream?
The gas stream contains 18 mol% hexane and the remainder is nitrogen.
2. How many moles of hexane are in the gas stream?
There are 18 moles of hexane in every 100 moles of the gas stream.
3. What is the total number of moles in the gas stream?
The total number of moles in the gas stream is not specified in the given information. It can be calculated by knowing the total flow rate of the stream and the mole fraction of hexane.
4. What is the purpose of using nitrogen in the gas stream?
Nitrogen is often used as an inert gas in many processes, including the production of hexane. It helps to maintain a stable environment and prevent unwanted reactions.
5. Can the composition of the gas stream be changed?
Yes, the composition of the gas stream can be changed by adjusting the flow rate of hexane or nitrogen. It can also be changed by adding or removing other gases in the stream.
11K
9K
