A glass marble is dropped down an elevator shaft
In summary, a glass marble is dropped down an elevator shaft and hits a thick glass plate on top of an elevator that is descending at a speed of 2.10 m/s. The marble hits the glass plate 7.5 m below the point from which it was dropped. If the collision is elastic, the marble will have a relative velocity of 10.03 m/s after the bounce. From this, the marble will have a velocity of -7.93 m/s relative to the ground, and will rise to a height of 7.93 m relative to the point of impact on the glass plate.
Salk13
[/B]
A glass marble is dropped down an elevator shaft and hits a thick glass plate on top of an elevator that is descending at a speed of 2.10 m/s. The marble hits the glass plate 7.5 m below the point from which it was dropped. If the collision is elastic, how high will the marble rise, relative to the point from which it was dropped?
v 2 - u 2 = 2gh
v 2 = u 2 + 2gh
[/B]
H = v 2 / 2g
H-h= required height
[/B]
v^2=(2.10 m/s)^2+ 2(9.81)(7.5m)
v= 12.31
12.31^2 / 2(9.81)
7.72-7.5= .22
not right answer though!
Hello Salk, welcome to PF :smile: !
There are a few things you must explain to me a bit further before I can help sensibly.
What is it the relevant equations are saying ?
Not ##v_2 = u_2 + 2 gh## because, at least if ##v_2## and ##u_2## are speeds, with the dimension of m/s, that doesn't fit dimensionally.
Perhaps you mean ##v^2 = u^2 + 2 gh## ? But what are ##v## and ##u## ?
From the next one I almost gather ##u^2 = 0## but I find it hard to believe that's what you mean.
So a bit more verbose, please, and we can get going.
Nice exercise, this is.
Oh, and do you get a green bar above the tekst you are editing ? With an x2 for subscripts and an x2 for exponents ? Very nifty !
That would be right if the marble were descending at 2.1 m/s initially, and fell a further 7.5m before hitting the glass. But the marble starts from rest - it's the 'ground' that's moving.
BvU sorry for the confusion on equation I meant to say v[2] = u[2] + 2(a)x with x=7.5 u= speed of elevator and v= velocity of ball before impact
haruspex okay I thought about finding the speed of the marble before impact by using conservation of energy. I am having trouble with getting the velocity of the marble with respect to the "ground" so i can calculate height using v[2] equation
BvU i tried using the green bar for exponents but they arent working so those are v squared
That's good - what answer do you get?
From energy you can calculate the speed relative to the lift shaft. If the elevator is descending at 2.1 m/s, what's the marble's speed relative to that?
I got 12.13 m/s relative to the shaft. Then, using relative motion, the marble should be 14.23 m/s relative to ground.
Are the marble and the glass roof traveling in the same direction or opposite directions before bounce?
they are traveling in the same direction
If the marble is falling at 12.13m/s and the glass plate at 2.1 m/s, what's the relative velocity?
14.23 m/s
Salk13 said:
14.23 m/s
No.
Consider this, if they were both descending at 2.1m/s, what would the relative velocity be? Hint: it wouldn't be 4.2m/s.
it would be 0. I would use the equation Vac= Vab+Vbc with a= marble, b=elevator and c= ground. If they are both falling to the ground, then Vac=Vbc=2.1 m/s, leaving the relative velocity to 0.
Right, so do the same with the marble falling at 12.13 m/s instead of 2.1m/s.
The relative velocity would be 10.03 m/s
Yes.
That's much better.
Right, so what would the relative velocity be immediately after the bounce?
10.03 m/s because the collision is elastic and kinetic energy is conserved
based on that would height be 5.127m ?
Height is relative to what ?
If you're talking about the height asked for in the problem statement, the answer is no.
yes I was talking about the height as in answer to question
height is relative to the point where the marble first dropped but how do you find the height (the answer) is there another way cause I am not seeing how to get this answer?
Check how you calculated the 5.13 m and think about what that means: starting from where is that 5.13 m ?
One step at a time... Yes, the relative velocity after the bounce is 10.03 m/s (in the other direction), so what now is the marble's velocity relative to the earth?
Bvu it should be from the ground which is the glass plate
haruspex -10.03 m/s
i know 10.03 m/s is relative to Earth but i don't know how it is different after the bounce
The velocity relative to the elevator was 10.03m/s before the collision, and it is the same after the collision. The elevator is moving, so the velocity relative to Earth will be different.
it is 7.93 m/s since the marble is going up and the elevator is going down
Good. So calculate the height to which it will rise from the position at which it bounced.
1. How does the speed of the elevator affect the marble's fall?
The speed of the elevator has no effect on the marble's fall. The marble will fall at the same rate regardless of whether the elevator is stationary or moving.
2. Will the marble hit the bottom of the elevator?
Yes, the marble will eventually hit the bottom of the elevator shaft. However, the time it takes to reach the bottom will depend on the height of the elevator shaft and the acceleration due to gravity.
3. Does the shape or weight of the marble impact its fall?
The shape and weight of the marble will not affect its fall. All objects, regardless of their shape or weight, will fall at the same rate in a vacuum due to the acceleration of gravity.
4. How does air resistance or friction affect the marble's fall?
In a vacuum, air resistance and friction will not have any effect on the marble's fall. However, in the real world, these factors may slow down the marble's descent slightly.
5. What happens if the elevator is moving at a constant velocity?
If the elevator is moving at a constant velocity, the marble will still fall at the same rate as it would in a stationary elevator. The marble will appear to be moving diagonally to an observer inside the elevator, but its vertical acceleration will remain constant.
11K
