- 6
if 2^n-1 is prime
prove that n is prime
I think you mean: if n^n-1 is prime where n is a whole, natural numberif 2^n-1 is prime
If n is not limited to natural numbers then I showed that if 2^n-1 is prime, n is not necessarily prime.The idea behind this problem is not setting 2^(n) - 1 (not 2^(n-1) like you have) equal to a prime in solving for n, (in virtually every problem in number theory n is limited to the natural numbers so for most cases this is an exercise in futility). The point here is, for example, 2^3 - 1 = 7 thus 3 is prime.
you interpreted 2^n-1 as "2 raised to the (n-1) power". The ordinary precedence (and what everybody else has understood the problem was) asks you to interpret it as "2^n, and then subtract 1".2^n-1=3
(n-1)ln2=ln3
Riddhish, we understood you, no need to clarify.actually its not 2^n-1 its (2^n)-1
C3H5N3O9 points out that if n is not a natural number it is not prime. For instance there is an irrational number n such that [tex]2^{n}-1[/tex] is equal to 13 which is prime but since n is irrational, it cant be prime. I dont know why C3H5N309 used the example of 3 and the logic there is not correct but the idea that one must specify that n is a natrual number is correct. Usually one write n to signify an integer an not an irrational number so the original poster obviously meant n to be an integer, but C3H5N309 apparently wants more care taken to specify what is meant.Riddhish, we understood you, no need to clarify.
As Dodo said, most people would take 2^n -1 to be (2^n) - 1, I am not sure why C3H5N3O9 thought otherwise.
A good site to obtain the factors of a number or mathematical expression such as [tex]2^{n} - 1[/tex] is http://www.alpertron.com.ar/ECM.HTM It does very well even with "large" numbers.Well is 97513144621 prime? All of the lists I checked do not have prime numbers listed that high.
You used A = 10, B = 11, ..., Z = 35 in base 26? That's somewhat odd.Well is 97513144621 prime? All of the lists I checked do not have prime numbers listed that high.
if 2^n-1 is prime
