Growing Basis in R: Exploring Primes & Integers
  • Thread starter pondzo
  • Tags
    Basis
In summary, the conversation discusses the concept of a "growing basis" in mathematics, where elements are added to a basis as needed to build other numbers. The conversation also touches on the creation of imaginary and complex numbers, as well as the Sieve of Eratosthenes. The idea of a basis in linear algebra is also discussed, and it is noted that the set of primes is not a basis in this sense. The concept of a subspace and the dimensionality of the real numbers is also briefly mentioned.
pondzo
169
Hi i was just wondering if there is any concept/theory/idea (or anything really) that relates to a growing basis (primarily in R) .
What i mean by a growing basis is the following; say you start off with one element in your basis and you encounter a number/vector that cannot be built by the element, this number that cannot be built then gets incorporated into the basis and becomes an element of it and this process goes on and on picking up more building elements as it encounters numbers that can't be built from the existing elements.
For example, in R, say the number you begin with is 2, then the next (integer) number you encounter is 3, which can't be built by 2, so 3 gets including in the basis. If this process were to go on and on, you would have a basis consisting of all primes (2,3,5,7,11,13,...) since all integers can be built from the primes. I hope that makes sense.
Thank you!
Mathematics news on Phys.org
Thank you for the links Ultra. Do you imply there is no such approach that exists to date? That's interesting you say it sounds like physics, I've heard that before!
That is very comparable to the ideas I'm thinking of, cheers for that. Another question, the set i gave as an example before, the set of primes, that isn't a basis is it? since a basis under the current definitions and axioms in linear algebra say that a basis is linearly independent, however, 2,3 and 5 are elements of the set of primes but 2+3=5 so 5 is a linear combination of other elements in the basis, and hence the set isn't linear independent.
This brings me to ask another question. How is R a subspace and how can it have 1 dimension (or am I completely wrong and R is not 1 dimensional?)? since by definition a subspace needs to be closed under scalar multiplication. In R, all numbers are a linear combination of 1, so you could say a basis for R is {(1)}, but i don't see how this basis is closed under scalar multiplication since it has, to me, no meaning to multiply (1) by a scalar quantity, c, as all scalar quantities are not defined within the basis {(1)}. Except for maybe ( 1 +/- 1 +/- 1 +/- 1 +/-...=c |c [itex]\in[/itex] R) but then if instead you used the basis {(2)} of R, there are scalar multiples, c, that can't be built by purely adding or subtracting 2 (ie 2 +/- 2 +/- 2 +/-...≠ c |c [itex]\in[/itex] R).
There are various notions of "basis" in mathematics. But you're right, the set of primes is not a basis in the sense of linear algebra.
The reals ##\mathbb{R}## are indeed ##1##-dimensional when you see it as a ##\mathbb{R}##-vector space.
I'm not sure what the two brackets mean. I would say that ##\{1\}## is a basis for ##\mathbb{R}##.
I don't see why a basis should be closed under scalar multiplication. In fact, a basis should not be closed under scalar multiplication. Since if ##\{e_1,...,e_k\}## is a basis and if ##e_1 = \alpha e_2## (for example), then the basis is linear dependent.
All we demand for a basis is that each element in ##\mathbb{R}## can be written as a unique linear combination of the basis ##\{1\}##. And indeed, any element ##x\in \mathbb{R}## can be written as ##x = x\cdot 1## and this is unique.
Of course, ##\{2\}## is a basis too and so is ##\{3\}##. In fact, if ##x## is a nonzero real, then ##\{x\}## is basis for ##\mathbb{R}##.
Is it a basis in any other sense?
My mistake, it was meant to be {1}
Sorry, I worded my question poorly and left it open for misinterpretation. What i mean was, say you have a basis for R, {x}, which as you say is a basis given its non zero. My problem is i do not see how {x} can span all of R. I realize that there are an infinite amount linear combinations of {x} that make up the infinite space of R (or is it Q, the rationals, since you can't make an irrational with a lin comb of {x}?). However, what does it mean to multiply a basis {x} by a scalar, c, since they are both 1 dimensional numbers and not all c can be built by x? for example say your basis is {2} then one such linear comb would be, for example, 5*{2}, but what does 5 mean to the basis {2} ( since 2 +/- 2 +/- 2 +/-...≠ 5), is it defined? does it exist? (in reference to the basis {2}).
Also, When designing a new mathematical model, is it acceptable and sometimes necessary to change the axioms that we assume in current mathematics, provided that we deduce logical and sound conclusions from these new axioms. And as long as the axioms are "sensible". I think this may relate to Godel's Incompleteness theory, but I'm not entirely sure how to apply it.
Cheers,
Michael
Cheers,
Michael
You can have any axioms you want as long as they are consistent. Of course, any proof you give in that system would NOT say anything about other systems used in "current mathematics". In particular, you cannot add a new axiom in order to prove a statement that is unprovable in current mathematics.
1. What is the purpose of exploring primes and integers in R?
The purpose of exploring primes and integers in R is to gain a better understanding of the fundamental building blocks of numbers and their properties. This can be useful in many fields of science, including mathematics, computer science, and cryptography.
2. How do you determine if a number is prime in R?
In R, you can use the isprime() function to determine if a number is prime. This function returns a boolean value, with TRUE indicating the number is prime and FALSE indicating it is not.
3. Can you generate a list of prime numbers in R?
Yes, you can use the primeFactors() function in R to generate a list of prime factors for a given number. You can also use the sieve() function to generate a list of prime numbers up to a specified limit.
4. How can you use R to explore the properties of integers?
In R, you can use various mathematical functions and operations to explore the properties of integers. For example, you can use the sum() function to find the sum of a list of integers or the prod() function to find the product of a list of integers.
5. Are there any packages or libraries in R specifically designed for exploring primes and integers?
Yes, there are several packages in R that are specifically designed for exploring primes and integers, such as the numbers and primefactr packages. These packages provide functions and tools for working with primes, factoring numbers, and exploring number properties.
  • General Math
  • Linear and Abstract Algebra
  • General Math
  • General Math
