RAD4921
- 347
- 1
It seem that if gravitational waves travel at C, that this is a hint that there is unification between gravity and electromagnetism. Didn't Einstein once remark about this?
Thanks RAD
Thanks RAD
Wouldn't what we perceive as 4-D gravity waves and EM waves both be special cases of 5-D gravity waves?But as far as I know, there is no mention of graviational/electromagnetic radiation unification?
Hurkyl said:I thought Kaluza and Klein did unify EM with gravity.
However, a naive attempt to convert this interesting geometrical construction into a bona-fide model of reality founders on a number of issues, including the fact that the fermions must be introduced in an artificial way (in nonsupersymmetric models). A less problematic approach to the unification of the forces is taken by modern string theory and M-theory.
Hurkyl said:Basically, I thought the only problem was that KK-theory was a classical theory, and not a quantum theory. Of course, I'm not an expert on this topic.
RAD4921 said:It seem that if gravitational waves travel at C, that this is a hint that there is unification between gravity and electromagnetism.
Symbreak said:There is a way we can conduct an experiement to test this hypothesis:
observe gravitational waves (GR) passing through a variable electromagnetic field (emf/v).
(the idea being, the displacement in the field caused by GR leads to the emf/v emmiting electromagnetic waves. The GR energy is transferred into light.)
... so somewhere along the line, is it possible to 'convert' GR into light?
Gravitational waves are ripples in the fabric of space-time caused by the acceleration of massive objects. They were predicted by Albert Einstein's theory of general relativity and were first directly detected in 2015.
Gravitational waves are detected using specialized instruments called interferometers, which use laser beams to measure tiny changes in the distance between two points caused by passing gravitational waves.
Einstein's theory of general relativity is a theory of gravity that explains how massive objects such as planets and stars create curvature in space-time, causing objects to move towards each other. It also predicts the existence of gravitational waves.
Detecting gravitational waves provides evidence for the existence of Einstein's theory of general relativity and confirms the predictions made by this theory. It also opens up new opportunities for studying the universe, such as observing events like the collision of two black holes.
Gravitational waves are an important piece of evidence in the search for unification in physics, as they provide a link between gravity and the other fundamental forces of nature. The detection of gravitational waves also helps to test and refine theories of unification, such as string theory and loop quantum gravity.
