Finding Solutions for a Challenging Integral
  • Thread starter Ornum
  • Tags
    Calculus
In summary, the conversation discusses various methods for solving the integral \int\frac{1}{1-x^3}dx, including using partial fractions, completing the square, and trigonometric substitution. The final agreed upon method is to use partial fractions to rewrite the integral as \int\frac{1}{1-x}dx + \int\frac{x+2}{x^2+x+1}dx, which can then be integrated using standard techniques.
Ornum
Hi, I've been trying to solve this integral for a while now, but I am still making no headway, any help would be much appreciated, thanks in advance.
[tex]\int\frac{1}{1-x^3}dx[/tex]
You tried splitting into partial fractions? I am just trying now :smile:
Not 100% sure on this, you'll have to check it but I think:
[tex]\frac{1}{1-x^3} = \frac{x + 2}{3x^2+3x+3} + \frac{1}{3-3x}[/tex]
That looks much easier to integrate if it is true :smile:
Couldn't you rewrite it as
[tex]\int {(1-x)^{-3}} dx[/tex]
and find the anti-dervative that way?
Because it is incorrect.
Oh, yeah. I see now. Only the x is cubed, not 1 - x
From the little I understand from integration (and at a guess you probably understand about the same) I don't think you can integrate that any other way than my suggested:
[tex]\int\frac{1}{1-x^3}dx = \int \frac{x + 2}{3x^2+3x+3} + \frac{1}{3-3x}dx[/tex]
It's fairly easy to manipulate that and make it possible to integrate.
Im not sure how you got those equalities, I get…
[tex]\frac{1}{1-x^3} = \frac{x + 2}{-x^4 -2x^2+x+2}[/tex]
Corrected:
[tex]\frac{1}{1-x^3} = \frac{x + 2}{-x^4 -2x^{3}+x+2}[/tex]
But this is not a partial fractions decomposition!
now I am not sure how you are getting
[tex]+ \frac{1}{3-3x}dx[/tex]
im not sure if this is right, but this is what i did...
[tex]\int\frac{1}{(1-x)(1+x+x^2)}[/tex]
[tex]\int((1-x)(1+x+x^2))^{-1}[/tex]
let u = 1 + x + x^2
du = 1+2x dx
[tex]2\int (1+u)^{-1} du[/tex]
[tex]2(u+\frac{u^2}{2})^{-1}[/tex]
[tex] 2(1+x+x^2+ \frac{(1+x+x^2)^2}{2})^{-1}[/tex]
The only method i could think of for doing this question is using partial fractions.
With this you obtain:
A - B = 0
A + B - C = 0
A + C = 1
Therefore,
C = 2/3
A = B = 1/3
and f(x) =
(1/3) * (1/(1-x) + (x+2)/(1+x+x^2))
Which you would then integrate. (upon further review, its the same thing as what zurtex got)
JonF, it can't be done using substitution (or atleast i don't see it). You made an error when you were substituting.
TI89ed it... didn't look too pretty!
Argh, cursed arithmetic
[tex] \int{(1-x^{3})}^{-1}dx = -\frac{1}{3}ln(1-x)+\frac{1}{3}ln(x^{2}+2x\cos({\frac{\pi}{3}})+1)
[/tex]
It is equation 2.144.2 in Gradshteyn and Ryzhik, pg 64
how evil! what an equation... is it any use to... umm... rememorize the table of integrals?
No- you've lost the "-1" power in the first term. That should be
[tex]\int((1-x)^{-1}(1+x+x^2))^{-1}[/tex]
and now the substitution doesn't work.
"how evil! what an equation... is it any use to... umm... rememorize the table of integrals?"
Believe it or not, it's actually easier to THINK!
In this case, you use "partial fractions" as you were told to begin with:
1-x3= (1- x)(1+ x+ x2 so
[tex]\frac{1}{1-x^3}= \frac{A}{1-x}+ \frac{Bx+C}{1+ x+ x^2}[/tex]
for some numbers A, B, C.
Multiply that equation by 1-x3 and you get
1= A(x2+ x+ 1}+ (Bx+ C)(1-x)
Since this is true for all x, in particular if we let
x= 1, 1= 3A so A= 1/3
x= 0 1= A+ C= 1/3+ C so C= 2/3
x= -1 1= A+ (-B+C)(-2)= 1/3+ 2B- 4/3 so 2B= 2 or B= 1
Now we need to integrate
[tex]\frac{1/3}{1-x}+ \frac{(2/3)x+ 1}{x^2+x+1}[/tex]
The first of those is just -(1/3)ln|1-x| (that's in Dr Transport's answer)
To do the second, complete the square: x2+ x+ 1= x2+ x+ 1/4+ 3/4= (x+1/2)2+ 3/4 so we break that into two integrals:
Now make the linear substitution u= x+ 1/2, du= dx, (2/3)x+ 1= (2/3)u- 1/3 and the integral becomes
[tex]\frac{(2/3)u}{u^2+ 3/4}- \frac{1/3}{u^2+3/4} [/tex]
The first of those can be done by the further substitution v= u2+3/4 and the second is an arctangent. That might reduce to what Dr Transport gave but it can be difficult to show that!
HallsofIvy, you seem to have got your partial fractions wrong. I tried making them into 1 fraction again and it didn't work. I am fairly sure that:
[tex]\frac{1}{1-x^3} = \frac{(1/3)(x + 2)}{x^2+x+1} + \frac{1/3}{1-x}[/tex]
As I stated on the first page.
The way i was taught to do it was to expand everything out, bring together x^2, x... terms together, factor things out and see what you need. For this example, expanding and combining yields:
1 = A(x^2 + x + 1) + (Bx + C)(1-x)
1 = Ax^2 + Ax + A + Bx - Bx^2 + C - Cx
1 = (A - B)x^2 + (A + B - C)x + (A + C)
Since you have no x^2 or x terms:
(A - B) = 0 A = B
(A + C) = 1 A = 1 - C
(A + B - C) = 0
Substitude that all into the last equation:
2A - C = 0
2(1 - C) - C= 0
2 - 3C = 0
C = 2/3
A = 1/3
B = 1/3
which will give you zurtex's partial fractions.
you accidently got a negative on that two; otherwise you get the same as above.
after looking at this again, if you complete the square on the denominator you obtain:
(x + 2)/[(x + 1/2)^2 + 3/4]
using a trig substitution you should be able to solve it
lol, sorry I could easily solve this if you want but I was just trying to help the person who made the thread to be put on the right track.
1. What is the purpose of "A little calculus problem"?
The purpose of "A little calculus problem" is to provide a mathematical challenge that requires the use of calculus concepts to solve.
2. What level of difficulty does "A little calculus problem" have?
"A little calculus problem" is designed to be a moderately difficult problem that requires a solid understanding of basic calculus concepts.
3. Can "A little calculus problem" be solved using any calculus techniques?
Yes, "A little calculus problem" can be solved using a variety of calculus techniques such as derivatives, integrals, and limits.
4. Is "A little calculus problem" a real-world problem or purely theoretical?
"A little calculus problem" is a purely theoretical problem and does not have a direct real-world application. However, the concepts used to solve it can be applied to real-world problems.
5. How can I approach "A little calculus problem" if I am struggling to solve it?
If you are struggling to solve "A little calculus problem", it is helpful to break it down into smaller parts and try to solve each part individually. You can also seek assistance from a teacher, tutor, or online resources for additional guidance and practice.
  • Calculus
