Momentum Problem: Solving a Football & Vase Collision
  • Thread starter Beowulf
  • Tags
    Momentum
When you want to divide 1.29 by 0.2, you can't just erase the 2 at the end, you have to divide 129 by 2.
Beowulf
Someone throws his .20-kg football in the the living room and knocks over his mother's .8 kg antique vase. Ater the collision, the football bounces straight back with a speed of 3.9 m/s, while the vase is moving at 2.6 m/s in the opposite direction. a) How fast did Tyrrell throw the football? b) If the football continued to travel at 3.9 m/s in the same direction it was thrown would the vase have to be more or less massive than .8 kg?
I'm not sure on how to get the Velocity of the football prior of hitting the vase.
I did figure out the vase's momentum is
.8 * 2.6 = 2.08
If the momentum of the football before it hit the vase was given I know it could be answer with
p/m=v
But I have no idea on how to get the velocity of the football prior of hitting the vase.
I also don't understand the second question at all.
It's all about conservation of linear momentum.
[tex]\vec{p_{initial}} = \vec{p_{final}}[/tex]
Let the initial velocity of the football be [itex]v[/itex]. Consider both the football and the vase as one entire system. The momentum of this system is conserved.
Remember that because momentum and velocity are vector quantities, you have to be careful with the signs. You can take the initial direction of travel of the ball as the positive direction, and anything moving in the opposite direction will have a negative velocity and momentum.
Get an expression for the initial momentum of the system in terms of [itex]v[/itex]. This is the sum of momentums of football and vase. Since the vase didn't move to begin with, it has zero momentum.
Then get an expression for the final momentum, taking care to get the signs right. The football will have a negative final momentum, the vase will have a positive final momentum.
Then solve for [itex]v[/itex].
For the second part, the initial momentum of the system is the same as in the first part. So the left hand side of the equation is the same, meaning the right hand side will also have to be the same. But now you have 2 positive quantities being added (since football and vase are traveling in the same direction). Can you figure out if the vase should be more or less massive in this case ?
I'm not sure if I did this correctly, but here is what I did. (From what I understood from your explanation)
Football Vase
m .2 .8
v -3.9 2.6
I used m=.1
v= -6.5
Then got the momentum to equal .65
Then I did p/m=v .65/.2=3.25 m/s
So I'm wondering if th answer is 3.25 m/s?
Im assuming they are not interested in friction, etc.
Does not seem your awnser is right, because how could he throw it, and bounce back at a faster rate? hmmm, remember what Curious3141 said.
Momentum initial = Momentum final
Football Vase
m .2 .8
v -3.9 2.6
I used m=.1
v= -6.5
The answer should be 6.5 m/s.
I don't understand what you're doing : what do you mean by "I used m=.1", etc ?
It's quite simple. You should have an equation like this :
mass of football*initial velocity of football = mass of football*final velocity of football + mass of vase*final velocity of vase.
You seem to have gotten the right answer, then you did something wrong by multiplying by 0.1. Why ? What's your rationale for this ?
Ya should be 6.5 m/s
Momentum Initial = Momentum Final
(MVi)of ball + (MVi)of vase = (MVf) ball + (MVf) vase
The .1 is not rational and I know how I got it but that's completely wrong, since .8 + .2 doesn't equal .1... I got confused with another problem I did earlier I guess.
So the initial velocity of an object thrown is the sum of the two final velocities of the vase and and the returning velocity of the ball? Because that's how it seems, just adding 3.9 + 2.6 = 6.5. Or it just worked out like that for this particular question?
With the formula you gave me I got 6.45 so I'm guessing your answers were rounded up and that chance of both final velocities been added up to 6.5 won't work on all problems?
.2 * Vi = .2 * (-3.9) + .8 * 2.6
.2 * Vi= 1.29
Vi= 1.29/.2
Vi= 6.45
It's just that way in this particular case because of the particular masses given. Don't assume it will work out this way in another question.
.2 * Vi= 1.29
Vi= 1.29/.2
Vi= 6.45
The answer is exactly 6.5. You miscalculated.
1. What is momentum and why is it important in solving a football and vase collision?
Momentum is a physical quantity that describes the motion of an object. It is the product of an object's mass and velocity. In solving a football and vase collision, momentum is important because it helps us understand how the objects will behave after the collision.
2. How do you calculate momentum in a football and vase collision?
To calculate momentum, you need to know the mass and velocity of the objects involved in the collision. In the case of a football and vase collision, you can use the formula p = m * v, where p is momentum, m is mass, and v is velocity. Make sure to use the same units for mass and velocity.
3. What is the law of conservation of momentum and how does it apply to a football and vase collision?
The law of conservation of momentum states that in a closed system, the total momentum before a collision is equal to the total momentum after the collision. This means that in a football and vase collision, the total momentum of the objects before the collision will be equal to the total momentum after the collision.
4. What factors can affect the outcome of a football and vase collision?
The outcome of a football and vase collision can be affected by factors such as the mass and velocity of the objects, the angle and direction of impact, and the elasticity of the objects. These factors can determine whether the objects will bounce off each other or stick together after the collision.
5. How can momentum be used to predict the outcome of a football and vase collision?
By calculating the momentum of the objects and applying the law of conservation of momentum, we can predict the outcome of a football and vase collision. If the total momentum before the collision is equal to the total momentum after the collision, the objects will bounce off each other with the same speed and direction. If the total momentum is not conserved, then the objects will stick together or move in different directions after the collision.
