Proving Real Numbers Satisfy Inequality
In summary, the problem statement is to prove that if a, b, c are real numbers such that \frac{1}{a+1} + \frac{1}{b+1} + \frac{1}{c+1} = 2, then \frac{1}{4a+1} + \frac{1}{4b+1} + \frac{1}{4c+1} \geq 1. The only solution to this problem is when a=b=c=0.5. The problem was solved using a contradiction by considering the difference between the inequality and the condition and showing that it leads to a contradiction.
murshid_islam
457
the problem statement is:
if a,b,c are real numbers such that [tex]\frac{1}{a+1} + \frac{1}{b+1} + \frac{1}{c+1} = 2[/tex]
we have to prove that:
[tex]\frac{1}{4a+1} + \frac{1}{4b+1} + \frac{1}{4c+1} \geq 1[/tex]
thanks in advance.
Mathematics news on Phys.org
Well I thought id at least prove a general class of the solutions, where a=b=c, but it turns out that the only solution is a=b=c=0.5. It is the only solution where the 2nd equtation is exactly 1. The others must be more.
I tried another case, where 2 solutions (a and b) are equal, and it shows a=1/(2c+1). That might help, perhaps we could prove every case to be true.
Condition:
[tex]\frac{1}{a+1}+\frac{1}{b+1}+\frac{1}{c+1}=1-\frac{a}{a+1}+1-\frac{b}{b+1}+1-\frac{c}{c+1}=2[/tex]
Hence,the condition is equivalent with:
[tex]\frac{a}{a+1}+\frac{b}{b+1}+\frac{c}{c+1}=1[/tex]
Inequality:
By similar simple algebra the inequality can be rewritten as follows:
[tex]\frac{4a}{4a+1}+\frac{4b}{4b+1}+\frac{4c}{4c+1}\leq 2 [/tex]
Now,let's consider the difference "Inequality-Condition":
[tex]\left(\frac{4a}{4a+1}-\frac{a}{a+1}\right)+\left(\frac{4b}{4b+1}-\frac{b}{b+1}\right)+\left(\frac{4c}{4c+1}-\frac{b}{b+1}\right)\leq 1[/tex]
Every expression within brackets is of form [itex]\frac{4x}{4x+1}-\frac{x}{x+1}[/itex].
[tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}?\rightarrow 4x^2-4x+1<0\rightarrow 4\left(x-\frac{1}{2}\right)^2<0\longrightarrow Contradiction![/tex]
QED
EDIT:BTW,this cute little problem was misplaced in dumb brainteasers section.
Elementar proof presented here is understandable even to 6th graders.:smile:
how do you get a contradiction here? i get:
[tex]\frac{4x}{4x+1} - \frac{x}{x+1} > \frac{1}{3}[/tex]
[tex]\frac{3x}{(4x+1)(x+1)} > \frac{1}{3}[/tex]
[tex]\frac{9x}{(4x+1)(x+1)} > 1[/tex]
[tex]\frac{9x}{(4x+1)(x+1)} - 1 > 0[/tex]
[tex]\frac{9x - 4x^2 - 5x - 1}{(4x+1)(x+1)} > 0[/tex]
[tex]\frac{4x^2 - 4x + 1}{(4x+1)(x+1)} < 0[/tex]
[tex]\frac{(2x-1)^2}{(4x+1)(x+1)} < 0[/tex]
[tex](4x+1)(x+1) < 0[/tex]
[tex]x \in \left(-\frac{1}{4}, -1\right)[/tex]
so where is the contradiction?
Ahh here's your problem murshid_islam, you know when you copyed this problem over from the brain teasers section? https://www.physicsforums.com/showthread.php?t=131366
Take a look at the original question, a b and c have to be POSTIVE. All the solutions to that quadratic inequality are negative, and therefore we reach a contradiction.
thanks Gib Z. but still, the contradiction tehno got is wrong, isn't it?
Why is the contradiction wrong? The inequaility has only negative solutions, which is contradictory from the original assumption of positive solutions.
tehno said:
[tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}?\rightarrow 4x^2-4x+1<0[/tex]
how do you get from [tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}[/tex] to [tex]4x^2-4x+1<0[/tex]
thats what i said was wrong?
Well I've tried for 30 mins now, i can't see how he got that either. Help tehno!
From here, x is positive, and so the denominator is always positive. So, for the inequality to hold, we require [itex]4x^2 - 4x + 1<0[/itex]. From here, the contradiction is obtained as in tehno's post.
1. What are real numbers?
Real numbers are numbers that can be found on the number line and include all rational and irrational numbers. They are represented by decimal or fractional forms and can be positive, negative, or zero.
2. How do you prove that real numbers satisfy an inequality?
In order to prove that real numbers satisfy an inequality, you must first substitute the real numbers into the inequality and then use algebraic operations to show that the inequality holds true. This can be done by simplifying both sides of the inequality until they are equal.
3. Can you give an example of proving real numbers satisfy an inequality?
Sure, for example, to prove that 2 is greater than 1, we can substitute 2 and 1 into the inequality 2>1 and then use algebraic operations to show that 2 is indeed greater than 1.
4. Why is it important to prove that real numbers satisfy an inequality?
Proving that real numbers satisfy an inequality is important because it allows us to determine the relationship between two quantities and make predictions based on those relationships. It also helps us solve real-world problems and make informed decisions.
5. Are there any special rules for proving that real numbers satisfy an inequality?
Yes, there are a few rules that need to be followed when proving that real numbers satisfy an inequality. These include using the same operations on both sides of the inequality, being careful with signs when multiplying or dividing by negative numbers, and checking for any extraneous solutions that may arise during the process.
  • General Math
  • General Math
