What is the force on a particle in an electromagnetic wave?
In summary: so the force would be pointing in the x direction but it would vanish if the particle and the wave were in the same direction.
stunner5000pt
1,461
Wangsness Exercise 24-6
A particle of charge q and mass m is traveling with a velcoity u i nthe field of a plane EM wave in free space that itself is traveling in the z direction.
Find the force on the particle.
What does this become for the special case in whic hthe particle is traveling in the same direction as teh wave?
What is the direction of the force?
Under what circumstances (if any) will the force vanish in this case??
2. The attempt at a solution
First of all I am stumped as how to find the force. Would i just simply use the lorentz force law??
If that is the case then
Suppose we assume the E to point in teh X direction and the B to point in teh Y direction then
[tex] \vec{F} = q (\vec{E} + \vec{u} \times \vec{B}) [/tex]
suppose the particle was traveling in teh Z direction then
[tex] \vec{F} = q (\vec{E} + u\hat{z} \times B\hat{y} ) [/tex]
[tex] \vec{F} = q (\vec{E} + uB (-\hat{x})) [/tex]
the force is pointing the x direction
The magnetic force would vanish if V is parallel to B
but the electric force will never vanish
is this even clseo to being right? OR am i sorely mistaken?
Thanks for your input!
I think you are very close...
I don't know if this is correct (if you can neglect the field and radiation caused by the particle)
consider the case when
[tex]\vec{E}=-\vec{v}\times\vec{B}[/tex]
however, for plane wave in free space,
[tex]E=cB[/tex]
which implies v must be a certain (and impossible) value.
the only way E would be equal to B is if the velocity of the particle was near the speed of light so its not possible for the force to ever be zero
I think you'll need oscillating terms like cos(k(ct-z)) won't you?
yea i had forgotten to mention that
[tex] \vec{E} = \vec{E_{0}} \exp(i(kz-\omega t)) [/tex]
[tex] \vec{B} = \vec{B_{0}} \exp(i(kz-\omega t)) [/tex]
1. What is the difference between a particle and a wave?
A particle is a tiny, localized object that has mass and occupies a specific position in space. A wave, on the other hand, is a disturbance or oscillation that travels through space and does not have a specific position or mass.
2. Can a particle also behave like a wave?
Yes, according to quantum mechanics, particles can also exhibit wave-like behavior, known as wave-particle duality. This means that particles can have both particle-like and wave-like properties, depending on the experimental setup.
3. How do particles and waves interact with each other?
Particles and waves can interact with each other through a process called wave-particle interaction. This occurs when a particle, such as an electron, interacts with a wave, such as light. The particle absorbs the energy from the wave, causing it to change its behavior or properties.
4. How are particles and waves related to energy and matter?
According to Einstein's famous equation, E=mc^2, energy and matter are two forms of the same thing. Particles, which have mass, are a form of matter, while waves, which carry energy, are a form of energy. This shows the interconnectedness between particles and waves.
5. Can particles and waves exist at the same time?
Yes, particles and waves can exist simultaneously in the same system. As mentioned before, particles can exhibit wave-like behavior and waves can interact with particles. This duality allows for a deeper understanding of the fundamental building blocks of our universe.
