Homework Help: A particle confined to a space
  1. Apr 1, 2012 #1
    Neutrons and protons in atomic nuclei are confined within a region whose diameter is about
    10^-15m = 1 fm
    a) At any given instant, how fast might an individual proton or neutron be moving?
    b) What is the approximate kinetic energy of a neutron that is localized to within such a region?
    c) What would be the corresponding energy of an electron localized to within such a region?
    2. Relevant equations
    uncertainty principle
    ΔxΔp ≥ h/(4π)
    3. The attempt at a solution
    I am having trouble visualizing how to go about the problem. I know I need to use the certainty prinicple in some way but I don't know how. I don't know if this is the right way to start but since we are confined to a sphere, would it be proper to apply the uncertainty principle in 3 directions?
    Δx*mΔv ≥ h/(4π)
    Δy*mΔv ≥ h/(4π)
    Δz*mΔv ≥ h/(4π)
    Solve for Δv for each direction and then use them to find the total magnitude.
    Or am I thinking about this wrong?
    If I can understand this then all the parts to this question will be simple.
  3. Apr 1, 2012 #2
    Dick
    Approximations using the uncertainty principle are just that. Approximations. I would think you would be ok with doing it in one direction. That should give you a good enough estimate.
  4. Apr 2, 2012 #3
    Ok so I will do everything in one dimension. Working with a proton(the work would be similar for a neutron)
    a.)
    Δx*mΔv ≥ h/(4π)
    Δv ≥ h/(4π*m*Δx)
    Δv ≥ 6.626E-34/(4π*1.67E-27*1E-15)
    So the minimum speed for a proton confined to that particular space will be
    = 31573672.2 m/s or 31573.6722 km/s or 31.5736722 Mm/s
    b.)
    A proton(I know it asks for E of a neutron but if I can do this general calculation then a neutron won't be much different) will have a minimum kinetic energy of
    E = (1/2)mv^2
    E = (1/2)(1.67E-27)(31573672.2)^2 = 8.324E-13 joules of energy
    c.)
    Is the same stuff except I'm dealing with an electron.
    Is what I have correct?
  5. Apr 2, 2012 #4
    Dick
    Yes, except you've only got 3 decimal places of accuracy in the proton mass and this is an approximate calculation anyway. So writing 31573672.2 m/s is kind of silly. Round it off. And is Mm/s really a unit?
  6. Apr 4, 2012 #5
    Ok I'll round the number a bit since this is an approximate calculation. By the way, what prevents Mm/s from being a unit?
  7. Apr 4, 2012 #6
    Dick
    You mean mega-meters/sec? I'm not saying it COULDN'T be a unit, but I've never seen it used. If you used it in a problem there's a pretty good chance it would be taken for millimeters/sec.
  8. Apr 4, 2012 #7
    Yeah mega-meters/sec is what I meant by that. I've never seen it used like this either. I was really just playing with SI prefixes just for the hell of it. It does look cleaner though:
    31500 km/s or 31.5*10^3 km/s
    vs
    31.5 Mm/s
    It could be taken as millimeters too but generally that is written as mm not Mm.
  9. Apr 4, 2012 #8
    Dick
    Sure, I'd just stick with commonly used units. I don't see much usage of mega-meters.
