Is the Motion of a Pendulum Simple Harmonic?
  • Thread starter Calpalned
  • Tags
    Pendulum
In summary, the restoring force for oscillations of pendulums is proportional to the sine of θ, rather than θ itself. This means that the motion is not simple harmonic motion, as it is not strictly sinusoidal and the period is not independent of the amplitude. While the SHM equations can still be derived for small angles, they do not accurately describe the motion for larger amplitudes.
Calpalned
297
My textbook states that for oscillations of pendulums, the restoring force is ##F = -mgsin(\theta)##. "Because F is proportional to the sine of ##\theta## and not ##\theta## itself, the motion is not SHM (simple harmonic motion)". I don't understand the last sentence.
For small angles, ##sin(\theta) ≈ \theta##.
Why is it that if something is proportional to ##\theta## it is SHM, but ##sin(\theta)## is not SHM? What's the difference?
How simple, or how complex an answer do you want?
One feature of simple harmonic motion is that the motion is sinusoidal as a function of time. It's also true that the period id independent of the amplitude.
Neither of those is exactly true if ##\ F = -mg\sin(\theta) \ ## .
The derivation of the SHM theory usually starts out with something like
F = -kx ...
that is the restoring force is directly proportional to the displacement.
If the force is directly proportional to θ, and θ is small, the SHM theoretical equations
can again be derived, but not if F is proportional to the sine of theta. So in summary
the pendulum motion can not be descibed by the SHM equations for large amplitudes
and it is only an approximation for small amplitudes.
1. Is a pendulum considered a simple machine?
Yes, a pendulum is considered a simple machine because it consists of a single moving part and utilizes basic mechanical principles to function.
2. What makes a pendulum simple?
A pendulum is simple because it consists of a weight attached to a string or rod that is suspended from a fixed point. This simple design allows it to swing back and forth in a predictable manner.
3. How does a pendulum work?
A pendulum works by harnessing the force of gravity. When the weight is pulled to one side, gravity pulls it back towards its resting position, causing it to swing back and forth in a repetitive motion.
4. Can a pendulum be used for scientific experiments?
Yes, a pendulum can be used for various scientific experiments, such as measuring the force of gravity, determining the length of a second, and testing the principles of energy and motion.
5. Is a pendulum used in real-world applications?
Yes, pendulums are used in real-world applications, such as clock mechanisms, seismometers for measuring earthquakes, and amusement park rides. They are also used in scientific research and investigations.
