Raap
- 29
Surfing the web for information about photons, I stumbled upon a blog which tries to argue for the theory that everything's made up of photons( a theory which I've always liked myself ). Here are some of the arguments:
Could someone with a more thorough understanding of the subject say their thoughts about some of the arguments presented, or even just the general idea? My own knowledge of physics is strictly a layman's, but I find the theory very interesting and would like to know from someone with actual knowledge in the area how probable it is.
All the arguments can be found here:
http://photontheory.com/TheEvidence.html
Case One: Matter can change into photons. An electron and a positron will annihilate each other when they collide. Two photons come out of the collision. Each photon has the energy of one of the particles. This would necessarily happen if the electron and positron were made of photons.
Case Four: Nothing moves faster than photons. No object can go faster than the speed of light. This would necessarily be the case if all objects were made of photons, which are simply bundles of light. Alternatively, we must either not believe the fact or speculate violating Occam's razor again.
Case Six: Time slows for a moving object. Time dilation is a natural consequence of the photon construct of nature. The repetition rate of patterns in Atoms must slow when atoms move. This is because the overall distance a photon must move to remain in the pattern is greater when the containing object is moving. Since the photon is already moving at the speed of light and can't move any faster, it uses more time to complete the pattern. The repetition rate of these patterns is the final arbiter of time in all things. So time slows for a moving object. And knowing this, we can also know that the effect of the slowing of time is accumulative for the moving object. We can solve the so called "twin paradox" simply by knowing which twin moved the greater distance relative to the special fixed frame of reference in space. No matter that our instruments can't determine that fixed frame, it still must exist. Instruments can't detect it because all instruments are effected by movement just exactly as they would necessarily be effected if they were made of photons.
Case Seventeen: Electrons show their wave structure. Electrons exhibit a wave structure that is well known. This structure is exactly as it would necessarily be if the electron were composed of one photon trapped in a pattern. The points of maximum amplitude of the electron must radiate the electric field in a sinusoidal pattern as the photon traverses the electron's circumference at the speed of light. This must necessarily give the electron a wave-like appearance that is detected and measured. This is also true of all the elementary particles. Since the proton and neutron are composite particles, their wave structure is more complex than that of an electron just as they must necessarily be if they are composed of multiple photon shells.
