• Support PF! Buy your school textbooks, materials and every day products Here!
A plane drops a missile
  • Thread starter DeathEater
a plane, traveling at 200 m/s in the X direction, drops a missile which has a constant acceleration of 7 m/s^2 at an angle 10 degrees below horizontal. If the plane is 1250 m high when it fires, how far (in the x direction) from where it was fired will the missile come down?
I have absolutely no idea how to start this problem... could I possibly break the 7m/s^2 into y and x components using cosine, sine and the angle of 350 (10 degrees below the horizontal)?
Answers and Replies
Bystander
1,208
Sounds like a start.
okay...well how can I possibly keep going after that?
phinds
Insights Author
2019 Award
16,165
6,174
How about if you go that far and see if anything occurs to you.
okay so I'm very much so struggling with this problem, but I tried to solve for the time when the missile will hit the ground
Δy=Voy(t) + ½ ay(t)2 → -1250= 0 (t) +½ (-1.2155) (t)2→ t= 45.35 seconds
is that correct so far?
Bystander
1,208
Looks about right --- haven't got my calculator to check for dotting "i's" and crossing of "t's" as far as sin(10°), but definitely the correct ballpark and handling of the numbers. Please continue.
after that, I plugged t into the equation Vfx= Vox +ax(t) → Vfx= 200+(6.894)(45.35) → and got 512.643 m/s for Vfx. I then multiplied the final velocity by the time (45.35 seconds) to get the Δx, which is 23248.3555 m . Is that correct?
Bystander
1,208
That non-zero initial velocity tripped you up. How far does the missile travel if the initial velocity is zero? You did fine with the y-component.
so should it just be (6.894)*(45.35) then? With that I get an initial of 312.643 and then multiplied by time I get 14178.3555 m
Bystander
1,208
You used "d = (1/2)at2" for the y-component. I told you that was correct.
Related Threads on A plane drops a missile
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
