A plane intersecting another plane
  • Thread starter Brad_Ad23
  • Tags
    Plane
In summary, the equation of the plane that passes through the line of intersection of the planes x-z = 1 and y +2z =3 and is perpendicular to the plane x + y -2z =1 is x+ y+ z= 4. This plane contains the entire line of intersection and is perpendicular to the given plane. There are infinite possible planes that satisfy these conditions, but the equation x+ y+ z= 4 is a simple solution that can be found by considering the parametric equations of the line of intersection and the normal vector of the given plane.
Brad_Ad23
502
Here is the question:
Find an equation of the plane that passes through the line of intersection of the planes x-z = 1 and y +2z =3 and is perpendicular to the plane x + y -2z =1.
Good luck!
Mathematics news on Phys.org
Homework? (Doesn't seem like the kind of problem one does for recreation.)
What do you mean "the plane"? There are an infinite number of planes that satisfy the condition- take anyone plane that does and move it "parallel to itself" along the line of intersection of the first two planes. In fact, since we are requiring that the plane is perpendicular to a plane rather than a line- there are an infinite number of planes perpendicular to a given plane.
The first thing you should do is find the line of intersection of the two planes: x-z = 1 and y +2z =3. We can write a parametric equation for the line by taking z= t, the parameter, and solving the other two equations for x and y in terms of z: x= z+1 and y= 3- 2z so the parametric equations are x= t+1, y= 3- 2t, z= t.
Given that the plane is perpendicular to x+ y- 2z= 1, it's normal vector is perpendicular to the normal vetor of that plane, <1, 1, -2>.
In other words, the equation of the plane must be of the form
a(x-x0)+ b(y-y0)+ c(z-z0)= 0 where a+b-2c= 0 so that if b and c are any two numbers then a= 2c- b gives a plane perpendicular to x+ y+ 2z= 1.
To guarantee that the plane passes through the given line, we can make (x0,y0,z0) a point on the line. Take t= 0 so that (1, 3, 0) is a point on the line. Take c= 1, b= 1 so that a= 2(1)-1= 1. Then the plane 1(x-1)+ 1(y-3)+ 1(z-0)= x-1+ y- 3+ z= 0 or x+ y+ z= 4.
x+ y+ z= 4 crosses the line of intersection of the two planes (at (1, 3, 0)) and is perpendicular to the plane x+ y+ 2z= 1 (it's normal vector is <1, 1, 2> and <1, 1, 2>*<1, 1, -2>= 1+ 1- 4= 0).
But my point is that that is one of many such planes. Taking b, c, and t to be any real numbers, the plane
(2c-b)(x-(t+1))+ b(y- (3-2t))+ c(z- t)= 0 passes through the line of intersection and is perpendicular to the given plane.
Yeah it was a homework. Nobody quite knew what to make of it, and the GSA (graduate student assistant) spent all night working on it and solved it using a system of 8 equations and 8 unknowns.
I thought of it as the two planes that intersect. They form a line L. Then this plane that we are searching for, P1 must contain L. And the plane P1 is perpendicular to, P2, must contain all the normal vectors (n2) of P1.
so,
n2dot(r-r0) would be the P1 plane.
with r representing (x,y,z) and r0 being some points on L
You'd have to give your GSA 100% in effort! An 8x8 matrix is pretty big, unless of course you had a computer.
Okay, the original post said " passes through the line of intersection" which I interpreted to mean that the line and plane simply intersected (in one point). Now it is clear that you intend the line to LIE IN the plane.
Fortunately, I gave the general formula for any plane, containing at least one point of the line of intersection and perpendicular to the given plane:
Since we want the entire line to be in the plane, we can take any point on that line to be our "base" point. In particular take t=0 so that the point is (1, 3, 0) and the equation of the plane is
(2c-b)(x-1)+ b(y-3)+ cz= 0.
The entire line being in the plane also requires that (2, 1, 1)
(t= 1) be in the plane so we must have
(2c-b)(2-1)+ b(1-3)+ c(1)= 2c-b- 2b+ c= 3(c-b)= 0.
Two points determine a line so that there is no way to determine b and c further. If we take c= b, then 2c-b= b and the equation of the plane is b(x-1)+ b(y-3)+ bz= 0 or bx+ by+ bz= 4b. As long as b is not 0 (which wouldn't give a plane) we can divide by b to get
x+ y+ z= 4 as the equation of the plane.
Notice that
(1+t)+ (3- 2t)+ t= (1+3)+ (t- 2t+ t)= 4 for all t so the entire line is in the plane.
also, the normal vector to the plane is <1, 1, 1> and
<1,1,1>*<1,1,-2>= 1+ 1- 2= 0 so this plane is normal to x+ y- 2z= 3.
The desired plane is given by x+ y+ z= 4.
Thank you. I suspected you didn't need to do a system of 8 equations like the GSA did. I will show him your solution (giving you credit of course) and he can realize that it was simple.
*as a note, I was doing the same thing you did, but I now see I made a silly error. I made an addition error so that I got a plane of x+2z =4
Hey, those GSA's are always showin' off!
1. What does it mean when two planes intersect?
When two planes intersect, it means that they share a common line or set of points. This line or set of points is called the intersection of the two planes.
2. Can two planes intersect at more than one point?
No, two planes can only intersect at a single point. This is because if two planes intersected at more than one point, they would no longer be considered planes but instead would be considered as parallel lines.
3. How can you determine if two planes will intersect?
If two planes are not parallel, they will intersect at a single point. This can be determined by comparing the equations of the two planes. If the equations are not parallel and not coincident, then the planes will intersect.
4. What is the angle between two intersecting planes?
The angle between two intersecting planes is called the dihedral angle. It is measured as the smallest angle between two intersecting lines that are perpendicular to the two planes at their point of intersection.
5. Can two planes be perpendicular and still not intersect?
Yes, two planes can be perpendicular and still not intersect. This occurs when the planes are parallel to each other. In this case, they do not share a common line or set of points, so they do not intersect.
  • General Math
  • General Math
  • General Math
  • General Math
