A question about 0
  • Thread starter caprija
In a whole number you can say whether it's negative or postive right?
So what would you call 0??????
would it just be called zero?
Answers and Replies
Hurkyl
Staff Emeritus
0 is nonnegative and nonpositive, and it is the only such integer.
so is there a term for it???????
I have to make a computer program that outputs whether the number is positive or negative, so when the user enters zero what should it output???
Galileo
1,991
A blue screen with fatal exception error, followed by automatic reboot.
but shouldn't the program output a different term when the number zero is typed in?
Why not just have the program output: "0 is neither positive nor negative"
StatusX
2,571
You could have the user ask "Is x positive or negative?" and when x is 0, instead of saying "positive" or "negative", just say "no".
So it would be sort of like the boxer/briefs paradox?
StatusX
2,571
Yea, same idea. Although I'm less troubled by the fact that 0 is neither positive or negative.
shmoe
1,992
"0 is going commando" seems like the appropriate output.
HallsofIvy
41,847
965
It was a joke, son, a joke! (And, in my opinion, a good one.)
I would vote for responding "neither".
arildno
Dearly Missed
10,025
134
Exactly!
It is what is INSIDE that is important; externals like the labels "positive/negative" are unimportant stuff. :smile:
It would probably output something along the lines of this:
http://i3.photobucket.com/albums/y100/Robokapp/untitledfff.jpg [Broken]
But honestly, although it should stay blank, it will...probably say something. I mean let's look at it this way, it's a positive thing to have zero debts, but it's negative to have zero income...I guess it's up to the maker's financiar life...
This should be in the psychology section.
-Job-
If the computer is using signed 2's Complement for number representation, then 0 will interpreted as a positive. Negative numbers would be the ones where the most significant bit is 1. Thus, 0 would be positive.
Some number representations have both a negative 0 and a positive 0, for example. But signed 2's complement is a popular representation, and your best bet is that 0 is a positive number, if this is for a Computer Science course.
In all honesty I think the problem lays in the meaning of the worlds "positive" and "negative". No matter how we look at it 0 wont turn negative... because it obviously involves a missing quantity. zero is the absence of quantity so nothing cant be missing.
wikipedia said:
In mathematics, a number is called positive if its value is greater than zero. See negative and non-negative numbers.
wikipedia said:
Zero is neither positive nor negative, neither a prime number nor a composite number, nor is it a unit. If zero is excluded from the rational numbers, the real numbers or the complex numbers, the remaining numbers form an abelian group under multiplication.
Now the last part of the second quote didn't look like english to me but...i quoted the whole paragraph...
Hurkyl
Staff Emeritus
Equivocation. :tongue: Your usage of those English words has absolutely nothing to do with the mathematical terms.
I assume you meant "words". Positive means bigger than zero. Negative means less than zero. What's the problem with that?
No, it is not. For example, when filling out a form, there's a huge difference between leaving
Children: _____
blank (absence of quantity), and filling it in
Children: __0__
with a zero.
The only "problem" here is that natural language likes to single out small quantities linguistically. "Zero" isn't the only word with this problem: "one" also has a lot of specialized language associated with it (not to mention the different spellings required for many unspecialized words). And even "two", "three", and "four" have some specialized words associated with them.
Children: __Maybe__
Positive and negative numbers are just 2 states of integers/real numbers. Then there is 0! Numbers are really in tri-state and zero is the bridge joining positives to negatives. So the output must be either positive, negative or zero.
However in computer science you are forced to accept that zero is a positive number since it is sometimes considered to be a natural number and is grouped with the positive numbers. So to conserve space of bits in registers they use just one bit (0 or 1) to describe the sign of the number instead of 2 bits (4 values) to include the zero state as well.
Is zero a natural number?
radou
3,120
No, zero is not a natural number.
shmoe
1,992
There's no universal convention on whether 0 is a natural number or not. Some authors include it, some don't.
HallsofIvy
41,847
965
Is the word "neither" too complicated for you?
CRGreathouse
2,824
Doesn't that vary mostly by field, though? Number theorists say one thing, etc.
:rofl: It's too difficult to "swallow" :yuck: although it makes sense...:grumpy:
shmoe
1,992
Probably it varies much less within a given field, but it can still vary.
Related Threads on A question about 0
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
