caprija
- 34
In a whole number you can say whether it's negative or postive right?
So what would you call 0?
would it just be called zero?
so is there a term for it??Hurkyl said:0 is nonnegative and nonpositive, and it is the only such integer.
but shouldn't the program output a different term when the number zero is typed in?Galileo said:A blue screen with fatal exception error, followed by automatic reboot.
StatusX said:You could have the user ask "Is x positive or negative?" and when x is 0, instead of saying "positive" or "negative", just say "no".
hypermonkey2 said:So it would be sort of like the boxer/briefs paradox?
caprija said:I have to make a computer program that outputs whether the number is positive or negative, so when the user enters zero what should it output?
caprija said:but shouldn't the program output a different term when the number zero is typed in?
Exactly!hypermonkey2 said:So it would be sort of like the boxer/briefs paradox?
wikipedia said:In mathematics, a number is called positive if its value is greater than zero. See negative and non-negative numbers.
wikipedia said:Zero is neither positive nor negative, neither a prime number nor a composite number, nor is it a unit. If zero is excluded from the rational numbers, the real numbers or the complex numbers, the remaining numbers form an abelian group under multiplication.
Equivocation. :tongue: Your usage of those English words has absolutely nothing to do with the mathematical terms.Robokapp said:it's a positive thing to have zero debts, but it's negative to have zero income
I assume you meant "words". Positive means bigger than zero. Negative means less than zero. What's the problem with that?In all honesty I think the problem lays in the meaning of the worlds "positive" and "negative".
No, it is not. For example, when filling out a form, there's a huge difference between leavingzero is the absence of quantity
shmoe said:There's no universal convention on whether 0 is a natural number or not. Some authors include it, some don't.
:rofl: It's too difficult to "swallow" :yuck: although it makes sense...:grumpy:HallsofIvy said:Is the word "neither" too complicated for you?
CRGreathouse said:Doesn't that vary mostly by field, though? Number theorists say one thing, etc.
In mathematics, 0 is known as the "zero" or "null" value. It represents the absence of any quantity or magnitude and is considered a neutral element in many operations.
Yes, 0 is considered a number in mathematics. It is a whole number and is located between the positive and negative numbers on the number line.
0 has several important roles in mathematics. It acts as a placeholder in the decimal system, marks the beginning of the number line, and is used as the additive identity in many operations.
No, it is impossible to divide 0 by any number. This is because division is essentially finding the number of times a certain quantity can fit into another quantity. Since 0 represents the absence of any quantity, it cannot be divided.
0 is used in equations and formulas as a constant or coefficient. It can also represent the initial value of a variable. For example, in the equation x + 0 = x, 0 acts as the additive identity and does not change the value of x.
