A question about solutions....
  • Thread starter Kaneki123
In summary, the conversation discusses the difference between physical mixtures and solutions, with a particular focus on solutions of polar-in-polar substances. While physical mixtures allow the constituent properties to be retained, solutions do not. The question is raised about how a solute, once dissolved into ions, can retain its original properties.
Kaneki123
120
Okay...In most of the solutions(I am talking about polar-in-polar solutions) , the solute becomes ions and these ions are surrounded by solvent molecules...A solution is a type of mixture, so its constituents retain their own properties...My question is that how, after the dissolution of solute into ions, can it retain its original properties?...
Likes cainorion
Chemistry news on Phys.org
In a very broad sense. But in general - no.
They don't.
The word "mixture" is used in different ways, which may be confusing. A physical mixture of two substances comprises two distinct phases, however finely divided and intimately dispersed they may be. (Phase: “A state of matter that is uniform throughout, not only in chemical composition, but also in physical state”). At the molecular level, the substances are not mixed; A molecules are surrounded by A molecules, and B molecules by B molecules (except for the interfaces, which comprise a tiny fraction of all the molecules). This is the only kind of mixture where the constituents retain their own properties. (Within their own phases, that is; a fine mixture of two substances may in bulk have an average property such as density.)
In a solution the substances are mixed intimately at the molecular level; A molecules are surrounded by both A and B molecules, and likewise for B molecules. A solution comprises a single phase. Its physical properties (e.g. density) are those of the solution; the properties of the individual components are not retained (there is no portion of the solution, however small, that has the density of pure A). However, to confuse things, we sometimes use the word "mixture" about a solution. We might talk, for example, of a 1% solution of ethanol in water, but if we mixed them in a 50:50 ratio we might refer to it as a "mixture" of ethanol and water (perhaps from the irrelevant difficulty of deciding which was the "solvent" and which the "solute"). And we describe two substances as "miscible" if they form a solution (i.e. they are miscible at the molecular level), and "immiscible" if they phase-separate and form a physical mixture. In particular, we are likely to refer to a "solution" of gases as a mixture.
In addition, forming a solution may involve chemical change, such as ionisation. In this case we usually call it a solution; we generally keep the word "mixture" for solutions where the components are not chemically changed.
Note that in a solution some of the constituent properties may be retained; e.g. A may be chemically reactive towards C both in the pure state and in solution, or it may absorb light at a given frequency both pure and in solution. But only in a physical mixture does it retain all its properties. And when we talk about a mixture in that way, I think it is usually to distinguish a physical mixture from a compound (e.g. a mixture of iron and sulfur from iron sulfide), not from a solution, which is neither a mixture nor a compound in that sense.
So are you asking, for an example, how NaCl dissolved in water would retain its properties from when it was in solid form?
What is a solution?
A solution is a homogeneous mixture of two or more substances. It is composed of a solute (the substance being dissolved) and a solvent (the substance doing the dissolving).
What are the different types of solutions?
The three main types of solutions are solid solutions, liquid solutions, and gas solutions. Solid solutions include alloys, liquid solutions include solutions like salt water, and gas solutions include solutions like air.
How are solutions different from suspensions?
Solutions are homogeneous mixtures, meaning that the particles of the solute are evenly distributed throughout the solvent. Suspensions, on the other hand, are heterogeneous mixtures where the particles of the solute are not fully dissolved and can be seen with the naked eye.
What factors affect the solubility of a substance?
The solubility of a substance is affected by temperature, pressure, and the nature of the solute and solvent. Generally, increasing temperature and pressure can increase solubility, while the nature of the substances can also play a role.
How can you increase the rate of dissolving for a solution?
The rate of dissolving can be increased by stirring or shaking the solution, increasing the surface area of the solute, and increasing the temperature of the solution.
  • Chemistry
  • Chemistry
  • Chemistry
  • Chemistry
  • Chemistry
