A question in lenear algebra
  1. Jan 15, 2008 #1
  3. Jan 15, 2008 #2
    HallsofIvy
    Your two questions are "Why are P(xR)= xR and P(xN)= 0?" and "what is the meaning of (I- P)(x)?".
    You are projecting x onto R. That is, xR= P(x), the component of x lying along R. If some vector, y, is already pointing in the R direction, P(y)= y. If you project again, since xR is already along R, projecting again just gives you the same thing again.
    As for P(xN)= 0, that is only true if N is orthogonal to R. Your picture does not make it look like that but you say "ker P= N". If xN is in ker P, then by definition of kernel, P(x)= 0. Are you sure you aren't told somewhere that R and N are orthogonal?
    Finally, (I- P)x= Ix- P(x)= x-P(x). It is x, with P(x) subtracted. If you drop a perpendicular from the tip of x to R, the intersection is at the tip of R- you have a right triangle with hypotenuse x, "near side" P(x), and opposite side x- P(x). If you "follow" the path from the origin of x to its tip, then down that perpendicular (call it "y"), you get to the tip of P(x): x+ y= P(x) so y= P(x)- x= -(I- P)x: -(I- P)x and so (I-P)x is always perpendicular to R.
  4. Jan 15, 2008 #3
    can you please make a drawing to explain this p(Xr) p(Xn)
    because i cant emagine all this components
    and you said aslo thats my drawing is not correct
    regarding the second part i didnt understand
    the theoretical part of it
    why are they doing
    (I- P)(x)
    what is the theoretical meenig of that
  5. Jan 15, 2008 #4
    HallsofIvy
    If you did not understand what I said before, then I recommend you talk to your teacher. Apparently you do not understand what a "projection" is.
  6. Jan 15, 2008 #5
    correct me if i got it wrong p is taking the parts of the given vector
    which is located on R
    then the the axes are supposed to be perpandicular
    i still cant understand the meening of the sign:
    why are they doing
    (I- P)(x)
Similar Discussions: A question in lenear algebra
Loading...
