A question on a<b
  • Thread starter Organic
In summary: OrganicAs I have said before, this is not "normal" mathematics. It is not "abnormal" mathematics, either. It is not mathematics. It is a word game. In summary, the conversation discusses the concept of a 1-1 correspondence (map) between any two real numbers within a given set [a,b]. The conversation also explores the idea of "non-normal" elements that may exist between two "normal" numbers and how they could potentially be useful in mathematics. However, it is noted that this is not traditional mathematics and is more of a word game.
  • #36
By using the empty set (with the Von Neumann Heirarchy), we can construct the set of all positive integers {0,1,2,3,...}:
code:
0 = { }
Huh... really? Let’s see. How do you define an empty set? The axiomatic theory of sets (ATS) defines it as:
("õ"="direct product", "!="="not equal", "Å"="direct addition", "Ú"="or")
A=Æ defined as "B(B !=Æ & AõB=Æ & A+B=B & "C(C=A equivalent to CõA=Æ)).
However,
"B(B !=Æ & AõB=Æ & A+B=B & "C(C=A equivalent to CõA=Æ)) Þ A=Æ Ú A="zero divisor", i.e. it is non-empty set.
i.e. without a non-empty set no one from mathematicians can’t defines an empty set. And this is nature of an empty set (or ATS) – it is necessary to definition of operations with sets.
1 = {{ }} = {0}
What it precisely means? Either an empty set is a subset of «1» (but «1» is not a natural number) or it is an element of «1». The ATS doesn’t let us define 1 (natural number) by non-number. Only a map correspond the elements of different nature to each other. And so on...
  • #37
("õ"="direct product", "<>"="not equal", "+"="direct addition")
AõA=0, B<>0, AõB=0, A+B=0: A=0.
However,
AõA=0, B<>0, AõB=0, A+B=0: A=0 or A="zero divisor", i.e. it is non-empty set.
using axiom 5 in
http://mathworld.wolfram.com/Zermel...nkelAxioms.html [Broken]
one can define an empty set to be such an x. then you can prove that all empty sets are equal, so it makes sense to give them all one notation.
the word set is undefined.
let's look at the first statement and replace "empty set" by the phrase "concept X." i'll also rule out your double negative. it becomes this: without concept X mathematicans can't define concept X. i disagree with this statement. you can certainly define any concept X you like. whether concept X "exists" is another story...
what do you mean when you add (direct sum) and multiply (direct product) sets? is that the same as union and intersection?
the empty set is an element of 1 in set theory.
0 = { }
1 = {0}
n = {n-1}
n+1 = n U {n}
  • #38
if you prefer, denote the empty set by e. then {e} is a superset of e containing e.
Excuse me, is e a subset of {e}, or e an element of {e}?
If e is a subset of {e}, then you’ll not define either {e} or e, because {e}=e, hence, {e, e}={e} imply e either empty set, or zero divisor. Without a non-empty set neither you, nor anybody else will not prove that e is empty set
If e is an element of {e}, then you’ll not prove that e is empty set, because in this case {e, e} always {e, e}.
  • #39
Originally posted by phoenixthoth
using axiom 5 in
Well, then how do you define zero divisor?
  • #40
element.
it's not about proving the set is empty. its emptiness is a postulation.
for any x, {x, x} = {x}
  • #41
  • #42
element.
0 = { }
1 = {0}
n = {n-1}
n+1 = n U {n}
Huh... well, well, well... I like it. Then following your logic:
0=1=2=3=4=5=6=7=8=9=...="infinity".
You really think so?
  • #43
using axiom 5 in
0 = { }
1 = {0}
n = {n-1}
n+1 = n U {n}
In the real
f: f({0})=1
The NBG (not ZF, because ZF hasn't the classes, hence, hasn't a the hierarchies) system of axioms.
  • #44
i don't see how you get 0 = 1 = 2 = ...
0 = { }
1 = {0}
two sets x and y are equal iff (a is an element of x iff a is an element in y).
0 is an element of 1 but 0 is not an element of 0 = { }.
therefore, it is not the case that a is an element of 1 iff a is an element of 0.
therefore, 0 != 1.
  • #45
0 = { }
1 = {0}
therefore, 0 != 1.
Exactly 0!=1, because 0! is number of permutations (there is an order!) {01}=1
but if {01}=1, then neither {01,02} nor {02,01} is not equal to {01}, because either a set has the order relations between the elements (even if there is only one element), or hasn't the order relations...
In the real your {0} (0 is an element of {0}) is equal to 0õ{1}, otherwise this {0} is imply that 0 is a subset of {0}, hence, {0}=0...
  • #46
!= means "does not equal."
i said, "therefore, 0 != 1." if ! is factorial, then it would be directly adjacent to the zero, which it is not.
if i meant ! as factorial, the statement 0! = 1 is a non-sequitor from my argument.
the statements above the conclusion demonstrated how the pair 0 and 1 don't fit the definition of set equality.
the conclusion was that the two sets are not equal.
i urge you to check out "elements of set theory" by enderton, "set theory" by stoll, or "axiomatic set theory" by suppes for all the details.
  • #47
From the ZF system of axioms may be proved (almost) all mathematics. In spite of the fact that the actual number of axiom is equal to infinity (Z5 and ZF9 are not the axioms, only schemes), but there is no these: {0,0}={0}. Empty set (or zero element) defined as the result of these operations:
B != A, A õ A = A, A õ B= A, A + B = B: A=0.
Otherwise, how do you define a zero divisor or a nilpotent device?
  • #48
{0,0} = {0} is not an axiom but it can be proven from the axiom of extensionality.
what are the definitions of A and B?
x is a zero divisor if it is nonzero and there is a nonzero y such that x õ y = 0. (source: http://mathworld.wolfram.com/ZeroDivisor.html )
in your equations above, neither B nor A is conclusively a zero divisor because A = 0. in every ring, B õ 0 = 0; that doesn't make B a zero divisor since then, every element would be a zero divisor.
here's how i would define nilponency:
this is pseudo-code:
let N be given. let m be a natural number and x = 1.
N^1 := N. (by, :=, i mean, "is defined to equal")
1. N^(x+1) := N õ N^x. update x so that x = x+1.
2. repeat step 1 until x = m.
when finished, N^m is defined. intuitively, N^m is
N õ N õ ... õ N, where there are m copies of N.
definition: N is nilpotent if N^m = 0 for some m.
  • #49
sets
x is a zero divisor if it is nonzero and there is a nonzero y such that x õ y = 0. [/qoute]
I want to see your definition of a zero divisor by ZF system axioms.
You've misunderstood. I define an empty set (or zero element). In other words, iif B != A, A õ A = A, A õ B= A, A + B = B, then A=0. If B != A, A õ A = A, A õ B= A, A + B != B, then A is a zero divisor. Your postulate {0,0}={0} doesn't allow defining a zero divisor.
  • #50
sets
zero divisor isn't a term used in set theory. therefore, there's no need to relate it to ZF axioms. zero divisors occur in rings; investigate how rings develop out of set theory. to write down the ZF axioms and then a sequence of statements leading to the definition of zero divisor would take a while.
are A and B allowed to be any two different sets?
is A õ A = A an assumption or a theorem?
is A õ B = A an assumption or a theorem?
is A + B = B an assumption or a theorem?
from the last equation, that B can be "cancelled" is an assumption. cacellation presumes both that there is a zero element and that all elements have inverses. therefore, this is a circular argument.
  • #51
Greetings,
Using presence of professional mathematicians at a forum, it would be desirable to ask the following question:
Is it present in the mathematics some a theory about self-organizing, development and complication of functions of information system (between elements of some data set)? I keep in a mind our universe as information system.
Thanks.
  • #53
Hi phoenixthoth, Hi Anton A. Ermolenko,
The concept of a set is like a "stage" where you can put elements and then find the rules, operations, relations and so on, within and among these elements.
The {} is the "stage" itself and it is not one of the elements "playing" on it.
The "stage" itself must be simpler than any "player" that plays on it, otherwise no player can express its full propery.
The "stage" has no signature at all, therefore it has no content(=emptiness).
It is as if I said that the silence is the base of any sound.
We cannot find any variations in silence, therefore the silence is invariant by its very own nature.
Therefore silence is more symmetric than any sound.
Now, please change silence by emptiness, and some sound by non-emptiness.
Organic
To be {true sentence} or to be {false sentence}, that is not the question.
To be(=~{}), or not to be(={}), that is the question.
  • #54
You wrote:
To Organic:
In general, your ideas aren’t new extension of mathematics, but may have application in the computer science.
Please be more spesific.
Thank you.
Organic
  • #55
See link below
http://forum.1tv.ru/index.php?act=Attach&type=post&id=249955
  • #56
Organic
Well, just tell me - how do you define an empty set within the framework of AST
  • #57
Thank you.
Organic
More specific in what? Why your ideas aren't new extension of mathematics?
Or why your ideas may have application in the computer science?
If first, then I've demonstrate the inconsistency of your definitions and suggestions with AST. There is no new mathematics.
If second, then I think that is wrong way (forum). What kind of physics we research up here?
  • #58
i wouldn't know since i wasn't "brought up" with AST; i was brought up on ZF and ZFC with a smattering of the von Neumann/Godel system. maybe a search on http://www.mathworld.com with "AST" will reveal the answer you seek.
in ZF, sets are NOT defined. then it is POSTULATED that there is a "set" with the property that for all x, x is not an alement of this set. the empty set is defined to be a set with this property.
  • #59
is there an online reference to AST? I've never heard of it.
the inconsistency of organic's definition with AST is not clear to me nor does it seem relevant because i believe he's using the ZF axioms.
the mathematics is new to me. it may have been already done by someone else, however.
the question about physics is irrelevant because this topic has been moved to the math section.
the connections to computer science aren't clear at all.
  • #60
You've misunderstood again... "AST" (the axiomatic theory of set), in other word, ZF or NBG (von Neumann/Bernays/Godel). Neither ZF, nor NBG hasn't an "axiom of empty set". Can you demonstrate this axiom within the framework of ZF or NBG? Just tell where it is?
  • #61
Which of them (axioms)?
Is the section of General physics>Theory Development math section? I thought, that it is a Physics theory development section... If I've misunderstood, then forgive me
  • #62
http://mathworld.wolfram.com/AxiomoftheEmptySet.html
note that ! means "not" in this case.
  • #63
i'm not sure why this topic is under physics theory development.
  • #64
Would you have it in Math?
  • #65
yes. as far as i remember, i found it under math where it had been moved to. i can't see what it's direct relation to physics is.
  • #66
Hi Integral,
This thread was opened by me under Mthematics > General Math, and it was there until yesterday.
Please check if it can be returned to its original place.
Maybe it is the right time to open Theory Development under Mathematics.
What do you think ?
Thank you,
Organic
  • #67
The ZF Axiom of the Empty set:
There is a set A such that, given any set B, B is not a member of A.
(There is a "stage" A with no "players" B)
Please tell me if you find any problem in this axiom.
Thank you.
Organic
  • #68
  • #69
Æ
  • #70
Dear Anton A. Ermolenko,
By [null] do you mean that you accept my point of view
which is:
An analogy: [null] is like an empty sheet of paper with no written thing on it.
Organic
<h2>1. What is the meaning of "a<b" in scientific terms?</h2><p>In scientific terms, "a<b" means that the value of a is less than the value of b. This is a comparison statement commonly used in mathematical and statistical analyses.</p><h2>2. How is "a<b" used in scientific research?</h2><p>"a<b" is used in scientific research as a way to compare and analyze data. It is often used in hypothesis testing and statistical analysis to determine if there is a significant difference between two variables.</p><h2>3. What is the significance of "a<b" in scientific experiments?</h2><p>The significance of "a<b" in scientific experiments lies in its ability to help scientists make conclusions about the relationship between two variables. It allows for a quantitative comparison and can provide evidence to support or reject a hypothesis.</p><h2>4. Can "a<b" be reversed to "b>a" in scientific analysis?</h2><p>Yes, "a<b" can be reversed to "b>a" as they both convey the same meaning - that the value of one variable is greater than the value of the other. However, it is important to maintain consistency in the direction of the comparison when interpreting the results of a scientific analysis.</p><h2>5. Are there any limitations to using "a<b" in scientific studies?</h2><p>While "a<b" is a useful tool in scientific studies, it is important to note that it is a simplified representation of a complex relationship between variables. It does not take into account other factors that may influence the data, and therefore, should be used in conjunction with other statistical methods for a more comprehensive analysis.</p>
2. How is "a
"a
4. Can "aa" in scientific analysis?
Yes, "aa" as they both convey the same meaning - that the value of one variable is greater than the value of the other. However, it is important to maintain consistency in the direction of the comparison when interpreting the results of a scientific analysis.
While "a
  • Other Physics Topics
  • Math Proof Training and Practice
  • Differential Equations
