Does Gravity "Lose" Pulling Power?
  • Thread starter Learnphysics
  • Tags
    Gravity
In summary, the conversation discusses the concept of conservation of energy in relation to the loss of magnetism in a permanent magnet and the pulling power of gravity. The expert explains that the decrease in magnetism is due to the realignment of atoms/molecules and that gravity, like other primary forces, does not fade with time. They also clarify that conservation of energy does not mean the magnet's force is "used up" and that it is the changes in position and velocity of objects that can be tracked.
Learnphysics
92
Well, i know i might be far oversimplifying this as its not understood properly by science yet but.
A permanent magnet seems to lose its magnetism slowly as it does work on other objects. (conservation of energy)
Is this in any way true for gravity, does a mass "lose" its pulling power after doing sufficient work. (of course we've never observed this happening).
And if this DOESN'T happen, isn't gravitational "pulling" is essentially infinite? sure you have to put in kinetic energy to increase the Gravitational potential energy, (the object has to start at a distance AWAY from the gravity-causing-mass) but other then that, can the pulling power of gravity be described as infinite, only dependent on the existence of another object with which to exert itself?
Hi there,
You seem to be mixing up things, like primary forces and conservation of energy. Magnetism decreases in a magnet due to the alingment of its atoms/molecules. If you rearrange them in their original position, you will increase the magnetic field.
Gravity, like the other three primary forces, does not fade with time.
You are absolutely right to say that gravity's action is infinite, but it decreases by the square of the distance between two objects. Therefore, very far away objects have pratically no more effect on us (this is where we say that it becomes negligeable).
Cheers
No no no! This is not right. Conservation of energy does not mean that the magnet's force somehow gets "used up." What it does mean is that the changes in position (distance from the magnet) and velocity of the "other object" can be tracked as trading off potential energy for kinetic energy.
1. How does gravity work?
Gravity is a fundamental force of nature that causes objects with mass to be attracted to one another. It is described by Newton's law of universal gravitation, which states that the force of gravity is directly proportional to the masses of the objects and inversely proportional to the square of the distance between them.
2. Does the strength of gravity change over time?
No, the strength of gravity does not change over time. According to Einstein's theory of general relativity, gravity is the curvature of spacetime caused by massive objects. This curvature remains constant unless there is a change in the distribution of mass in the universe.
3. Can gravity be turned off?
No, gravity cannot be turned off. It is a fundamental force of nature and is always present. However, its effects can be counteracted by other forces, such as electromagnetic or nuclear forces.
4. Does gravity have an end point?
No, gravity does not have an end point. It is an infinite force that extends throughout the universe. However, its strength decreases with distance, so it becomes weaker the further away an object is from the source of gravity.
5. Can gravity "lose" its pulling power?
Gravity cannot "lose" its pulling power. As long as an object has mass, it will always be affected by gravity. However, the strength of gravity may appear to decrease in certain situations, such as in space where there are no other large masses nearby to exert a gravitational force.
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Classical Physics
