A radial acceleration problem.
  • Thread starter cheater1
[PLAIN]http://img508.imageshack.us/img508/6861/21296472.jpg [Broken]
I tried to get a_rad and if i didn't make any mistake, then a_rad = 15.79 m/s. I need to find angle when the bean is at vertical equilibrium.
a_rad= v^2/R = 4(pi)^2R/T^2
circumference= 2(pi)R
v= 2(pi)R/0.25 sec = .2pi/0.25= .89m/sec
a_rad= 4pi^2(0.1)/.25= 15.79 m/s^2
Answers and Replies
PhanthomJay
506
This problem is a bit more complex than that. You have to look at the forces acting on the bead at angle beta, its weight and the normal force, where the net force in the vert direction is 0, and the net force in the horiz direction is the horiz component of the normal force, as caused by the centripetal acceleration, w^2(R), where R is not the radius of the circle.
Will this be the direction of a_rad?
PhanthomJay
506
NO, the hoop is not rotating about its center point, it is rotating about the vertical axis, that is, out of and into the plane, as if you were spinning a top.
so that means the a_rad is pointing right from the bead?
PhanthomJay
506
Yes.
PhanthomJay
506
Just to check is this right?
No. Firstly, r is not 0.1; as you noted before, the radial acceleration points to the right from the bead, so that is the value of "r" to use, the distance from the bead to the vertical axis in the horizontal direction. Also, it is better to use the angular speed instead of the out of plane tangential speed, that is , a_radial = w^2(r), where r = R*(____??___), and w is 4 rev/s, or w = 8 pi rad/s
Ok, I got r=(sinB)R , since the hoop is spinning, the bead will be going up. As it goes up r will will be changing with respect to angle.
a_radial = w^2(r)
where you get this?
PhanthomJay
506
Yes, if the rotation speed was increased or decreased, then r would change with respect to the angle.
where you get (a_radial =w^2r)?
Since a_radial= v^2/r, and v=wr, then a_radial = w^r^2/r = w^2(r) (where w = omega, the angular speed in rad/sec)
This is confusing me. v= wr, shouldn't speed be just 4rev/s ?
edit: nvm the v= rev/sec , 1 rev= 2(pi)R, and therfore v = 4(2piR) / sec = 8(pi)R / sec
PhanthomJay
506
No, w= rev/sec= 8(pi)radians/sec, then v=wr = 8(pi)r/ sec, where r = RsinB
I see it.
Edit: Got it!
angle = 81.07 if I did this right.
[PLAIN]http://img176.imageshack.us/img176/2347/32500903.jpg [Broken]
Picture for who any1 wants to see what I'm doing.
r=(sinB)R , R = 0.1m
T=4rev/sec
V= 4(1 rev)/sec = 4(2(pi)r)/sec
a_rad= v^2/r , (8pi*r)^2/r = (8pi)^2 * r
sinB= Fx / x rearrange to get Fx, Fx= xsinB
cosB= (mg)/x rearrange to get x, x= mg/cosB
Pluged in what I know.
(8pi)^2rm = sinB(mg)/cosB
(8pi)^2r / g = sinB/cosB m cancle out
(8pi)^2(sinBR) /g = sinB/cosB replace r, r = r=(sinB)R
(8pi)^2R / g= 1/cosB
B= cos^-1 [ g/ (8pi)^2R ] = 81.07
Thanks a lot for you help PhanthomJay.
PhanthomJay
506
That's the biggest thanks I ever got,
You're Welcome!
Did you get parts b and c?
You're Welcome!
You really did help me out a lot.
Yup finished b and c.
Related Threads on A radial acceleration problem.
9K
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
