A radiometry problem, please help! :-)
  • Thread starter Hodranoel
The exercise i have is as follows:
A flat plate (measuring 0.5 meter by 0.5 meter) is placed on the highest mountain in the landscape, exactly horizontal. It is a cloudy day, such that the sky has a uniform radiance of 1000 W/ m^2 sr.
The plate has a uniform Lambertian reflectance p=0.4.
What is the exitant radiance leaving the center point of the plate in a direction 45 degrees from the normal? In a direction normal to the surface?
Would you help me please?
Thank you in advance!
Boulayo
Answers and Replies
Ok... maybe i've solved it but i still have some doubt.
The answer should be: It's 400(pi) W/m^2 in both cases of 45° and 0° because the surface is Lambertian.
The irradiance on a point of the surface is 1000(pi) W/m^2, then the reflected radiosity is 400(pi) in every direction because it's multiplied with the reflectance.
Can you confirm it? Thanks! :-)
Related Threads on A radiometry problem, please help! :-)
  • Last Post
